Old 03-19-2012, 09:23 AM   #21
My 34 Ford
My 34 Ford's Avatar
Default Re: Rear Hub Puller
Hi Scott, Did not know this item existed, I only saw the more expensive one from Mac's. Now there are 4 choices for a puller. This item looks like it will do the job just fine using the same principal as the others and at a lower price. Thanks for the information.
My 34 Ford is offline   Reply With Quote
Old 03-19-2012, 11:16 AM   #22
Karl Wolf
Karl Wolf's Avatar
I used the KRW puller on a Ford rear, the drums were last off in the early 50's... With an air wrench, heat (lots) and a 3 lb. hammer... It would NOT come off... Period.
I wound up taking an abrasive wheel to the hub- along the length of the axle, on top of the keyway... And, full on again with the air wrench and hammer, it popped off.
Point is, any other puller would have been toast. For the KRW puller, just another day at the office...
Karl
Karl Wolf is offline   Reply With Quote
Old 03-19-2012, 11:44 AM   #23
richard crow
i have never saw a hub that the krw puller could not pull. karl you should of used a 10 lb sledge 3 lb hammer onley gets it mad if it,s realey frozen .don,t be affread to hit it you woun,t brake it . it is the best money can buy the other is an attempt there are two things in life that can,t be inproved. 1-is the krw puller the other is some thing a woman has
richard crow is online now   Reply With Quote
Old 03-19-2012, 11:57 AM   #24
ken ct
The Vintage Presion, what holds the 2 halves of the puller,it dosen't show any thing in th pics[a sleeve or something ???? ken ct.
ken ct is offline   Reply With Quote
Old 03-19-2012, 12:10 PM   #25
Old Henry
Old Henry's Avatar
Yes. The sleeve is what's laying behind the half that's laying down. When the sleeve is on it looks like the top image.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 03-19-2012, 02:14 PM   #26
Scott De Shields
Scott De Shields's Avatar
I have had this puller for some time. Is this the one you are talking about?
Scott De Shields is offline   Reply With Quote
Old 03-19-2012, 03:46 PM   #27
My 34 Ford
My 34 Ford's Avatar
Hi Scott, What you have is the puller made by Winfield Tool Works. This is a super puller and is a reproduction of the KRW puller made years ago. I was asking about the puller made by Vintage Precision which seems to be an excellent copy of the original puller made by KRW and your puller made by Winfield Toll Words. The price for the Vintage Precision puller is less than the other two and I was hopping that someone that had one could attest to the quality of the steel used in its manufacture and its ability to stand up as a club tool after multiple uses. Best regards
Old 03-19-2012, 04:43 PM   #28
Marv
Marv's Avatar
Macs sells a knock off hub puller for $2.90. I do not own this particular one but i have an original one from back in the 30's and it works great. Scew it on the axle till it bottoms out and leave the wheel on the ground that you want removed and hit with a sledge. It works every time for me. They recomend that you jack the wheel off the ground on the opposite side from the one you want removed. Marv
Marv is offline   Reply With Quote
Old 03-19-2012, 06:46 PM   #29
37fordpickup
On one of these sites someone said they went to Harbor Freight and bought one of their gear pullers with 2 arms. I was in HF recently so I thought what the hell, it's less than $13 so I bought, came home, tried it and it worked fine.
37fordpickup is offline   Reply With Quote
Old 03-19-2012, 06:53 PM   #30
B-O-B
B-O-B's Avatar
If you want to go the harbor freight route but the pitman arm puller & relieve the center to fit the hub. Works good & better than pulling on the studs. I think it cost less also.
B-O-B is offline   Reply With Quote
Old 03-20-2012, 12:32 AM   #31
Karl Wolf
Karl Wolf's Avatar
I've seen a bunch of rear drums, this one was one for the books... I can get a better hit with a 3 lb. hammer than a 10 lb., I'll bet...
I did get it off, though
Karl
Old 11-04-2019, 07:36 PM   #32
johndee138
johndee138's Avatar
The altered Harbor Freight pitman arm puller worked great for me. I had to grind the jaws a bit to get it to fit over the hub, snugged it up and a few taps with a hammer and off popped the drum. Its worked on a number of hubs so far.
johndee138 is offline   Reply With Quote
Old 11-05-2019, 05:40 PM   #33
supereal
supereal's Avatar
The Winfield Tool Works puller can't be beat. I have had mine for many years. I know they are expensive, but there is no such thing as good, cheap, tools. A bent drum or ruined axle threads is not cheap!
supereal is offline   Reply With Quote
Old 11-05-2019, 05:50 PM   #34
Mart
Mart's Avatar
This is an old thread recently bumped.
I use the Vintage Precision version as it was available and to me a reasonable price.
I show it in use in this video.
https://youtu.be/i26ZSqwFIF0
In the video I state that if you don't think you are going to break something when tightening it, the hub wasn't tight enough.
I stand by that.
If you are using an inferior puller if it feels like you are going to break something, you probably will.
Mart.
Old 11-05-2019, 06:11 PM   #35
19Fordy
19Fordy's Avatar
This was posted on HAMB in 2012. Read the last sentence of this post.
Winfield Tool Works makes the relica of the KR Wilson Tool.
Just so people know, Winfield Tool Works still produces the hub pullers. My father was the owner and my brother has taken over. They are exactly the same and are still produced by the same manufacturer. New Address.
Winfield Tool Works can be reached at
3 Enterprise Drive
East Setauket, NY 11733-3724
Phone: (631) 928-3316
Fax: (631) 928-3221
Here's one for sale on Ebay at a very good price, so far. I paid $150 new 10 years ago from Winfield.
https://www.ebay.com/itm/1939-Ford-K...0AAOSwHGtdvcNf
Old 11-05-2019, 07:42 PM   #36
Mart
Mart's Avatar
What's the current price of that beauty?
Old 11-05-2019, 08:19 PM   #37
Darrell S
Darrell S's Avatar
3 Enterprise Drive
Fax: (631) 928-3221
The one on Ebay is said to be for a 39. Are there different tools?
Darrell S is offline   Reply With Quote
Old 11-05-2019, 08:45 PM   #38
19Fordy
19Fordy's Avatar
$101 dollars US
I think 39 and 40 use the same Ebay puller. The Winfield hub puller I have for my 40 looks the same.
Old 11-06-2019, 09:52 AM   #39
uncle buck
uncle buck's Avatar
Unfortunately Winfield Tools discontinued the pullers several years ago and told me they had no plans to reintroduce it earlier this year. I got lucky and bought one on ebay and paid much more than the current one posted is at
uncle buck is offline   Reply With Quote
Old 11-06-2019, 10:59 AM   #40
Tim Ayers
http://www.vintageprecision.com/prod...ers/index.html
What about the Vintage Precision version? It looks like a beast.
https://www.ebay.com/itm/Ford-Lincol...c6da%7Ciid%3A1
Then there is this one as well.
