Old 04-02-2019, 09:35 AM   #1
jplawman
jplawman's Avatar
Default 1932 ford roadster quest
please show or tell me if there is material between the frame and the steel body or do the sub rails meet directly against the frame???
jplawman is offline   Reply With Quote
Old 04-02-2019, 10:22 AM   #2
Andy
Default Re: 1932 ford roadster quest
There is woven strap that is used. Available from suppliers. The last bolt in the back is not designed to be pulled tight. There was a rubber block there.
Andy is offline   Reply With Quote
Old 04-02-2019, 11:17 AM   #3
DavidG
DavidG's Avatar
Originally there was 1/16" x 2" woven webbing from the front edge of the firewall legs back until the start of the frame kick up for the rear axle. From there rearward there were two 2" x 2" rubber pads on each side. The rearmost was 1/4" thick; the one forward of that was 1/8" thick.
As shown below, there was a running change in the rearmost body-to-frame attachment to prevent cracks in the rear edges of the quarter panels. It involved more than just not tightening the rearmost body-to-frame bolts.
This illustration and hundreds more are all in the V8 Club's The 1932 Ford Book, A Production Chronicle and Restoration Guide.
Old 04-03-2019, 10:07 AM   #4
cas3
i just did this to my 34, and made a nice tool to cut the holes. the material is tuff, my gasket puncher tool would not make a good cut, so i took an old 5/8 hole saw with some busted teeth, ground them all off and sharpened the edge. you can find center with an awl, then poke it thru, then you have a hole started for the bit in the center of the hole saw, then saw the hole on a piece of wood with cordless drill. it makes a perfect hole very quickly.
Old 04-03-2019, 10:19 AM   #5
jplawman
jplawman's Avatar
thank you ford barn, body is married to the frame now on to the fenders.
