02-28-2018, 10:36 PM | #1 |
cross references
Can anyone please provide cross reference numbers for the following differential OEM bearing numbers with modern replacement numbers?
Side bearings 32-36; cup # 18-4222 cone # 18 4221 rear pinion straddle bearing 32-48; # 18-4625-A Front pinion bearings 35-48: cup 48-4616 cone 48-4621 Thank you, Brian
02-28-2018, 11:42 PM | #2 |
Re: cross references
Here's what I had saved . Remember that the pinion race is a double cup, not a separate front & rear cup.
02-28-2018, 11:50 PM | #3 |
Thank you Ken, perfect!! This barn is such a valuable resource. Brian
03-01-2018, 04:26 PM | #4 |
Be prepared to go back to work to pay for them Brian,they are exps
And DONT use the repo ones some suppliers sell, use only Timkin, Ford,Bower, or a known manufacturer, Lawrie |
03-01-2018, 04:57 PM | #5 |
What Lawrie said X2 on the repo ones. Nothing but trouble.
03-01-2018, 09:15 PM | #6 |
And DONT use the repo ones some suppliers sell, use only Timkin, Ford,Bower, or a known manufacturer," Lawrie Lawrie, what exactly is a repo bearing? Do you mean counterfeit? |
03-02-2018, 03:58 AM | #7 |
The repo,(reproduction) bearings I,m talking about are the ones one of the suppliers advertises in the magazine sells,Mate bought a set for a rear end I was doing for him,they where junk,came in a non descript white box,the bearing surface was as rough as concrete.
I woud NOT use them . Check before you do. Lawrie |
03-02-2018, 11:40 AM | #8 |
If parts such as bearings, races, etc. have no manufaturer name on them they are usually junk.
03-02-2018, 12:25 PM | #9 |
duplicate post, sorry
03-02-2018, 12:31 PM | #10 |
I was looking for Timken bearings and even some of them are made in India.
I look on Epay for old stock Timken, Bower or SKF bearings. Bob |
03-02-2018, 02:50 PM | #11 |
So far I've never had a problem with a Timken bearing regardless of the Country of manufacture. Maybe I've just been lucky. But I do know that those unmarked bearings that come in plain white boxes are pure junk.
03-02-2018, 04:14 PM | #12 |
I have all those bearings usa made only.
