02-14-2017, 09:47 AM | #1 |
Early Ford V-8 Parts 4 Sale
City:
Rising Sun
State:
Maryland
Price:
in ad
Prices DO NOT include shipping costs. Page down to see complete listing of parts. PM/email me if you have any interest.*
If you have any '35 parts you might like to trade for any of these parts, please PM or email me. > Wanted...Looking for a '34 luggage rack with brackets for a friend in our EFV8 Club RG36. Could be an original accessory or a reproduction. Send me a pm with details, cost, etc. ● Ford script 2LF battery. Could be gutted and used to conceal a no mantainence gel cell type battery. $75.00 ● '37 column drop. Nice, complete and original drop removed from a restored coupe that was being street rodded. Smooth working mechanism and ignition lock cylinder with key. Use as is in a driver, or repaint the housing and use in a restored show car. $250.00 ● '36 column drop. Nice, complete and original drop that's on a '36 steering column being parted out. This drop has a one year only ignition lock cylinder with keys. Use as is in a driver, or repaint the housing and use in a restored show car. $250.00 ● '36 under radiator splash pan for passenger car or light commercial vehicle $90.00 ● '33-'41, 3 bolt timing gear cover/front distributor mount in good condition... $25.00 ● '35 -'36 tudor sedan left and right side doors. These doors were stored leaning against the side of a shed/barn, and were protected by the roof overhang. However, the bottoms did not fair well due to ground moisture. Someone with sheet metal skills can repair these, or salvage the side panel skins, and other parts, to repair other doors. $75.00 each. l will not to ship these, buyer must pick up, or arrange shipping, or we could possibly make some type of pre arrangement where I would deliver these to a car show or swap meet that I plan to attend on the East Coast. ● '35 - '36 right and left rear doors for fordor sedan. A nice pair of doors requiring little or no repairs before installing. Original paint and some original pin striping still exists.... $550.00 for the pair. l do not want to ship these, so buyer must pick up or arrange shipping. ● '37 Ford original passenger car gas tank. This tank could as is on a driver, or restored for a use on a show car. There appears to be a dent on the lower front area, or maybe it was made this way for the purpose of clearance. See attached pictures. $135.00 ● '40 - '48 side load transmission cases, and side covers with shift levers, in good condition. Gears were removed from these cases and used to upgrade earlier top load transmissions. If you have a dameged case, with good gears, you could drop your gears right into these cases and be back in business. $30.00. Rear transmission mount is not included with case. ● '34 to '41 used camshafts for 60 & 85 hp engines. Some of these are considered to be the early "long" cams, with front hub for a press-on timing gear, and others are later for bolt on timing gears. These cams can be used as is for a stock engine rebuild, or as a core to have reground into a preferred lift cam, such as a KIWI L100, reground by fellow Fordbarn member, "KiwinUS" Tony...$60.00 ea./(2) for $110.00 ● '35 - '38 brake & clutch pedal assembly. Would need new bushings, but otherwise in nice original condition. $75.00 ● '33 - '36, '37 - '48, and some '49 - '53 Ford water pump cores for rebuild. You would get a good housing, and pulley. All other components will be removed. I can either ship these cores directly to Skip Haney for rebuild, or to your location, whichever you would prefer. $25.00 ea. ● (2) '37 85hp passenger car radiators in nice condition. One is a used original and the other one has been previously recored. $200.00 for either radiator. ● '36 original part numbered passenger car hood ornament in useable condition. It looks like the very tips of the "V" are missing, but have been smoothed down and rechromed or polished in that area or maybe it was made this way originally, I am not sure. Look at the attached picture and decide for yourself. A great piece for a driver vehicle @ only $25.00 ● '36 passenger car rear spare tire mounting bracket $35.00 ● '35 passenger car rear spare tire mounting bracket $35.00 ● Pair of '49 - '53 Mercury cast iron 8CM heads in good condition. Most of the original paint is beneath the oil/dirt coating. $30.00ea./$55.00/pr. ● '49 - '53 Mercury cast iron intake manifold with 4 stud carburator mounting $45.00 ● '48 Flathead 8rt engine block & crankshaft removed from a '48 1/2 T pu truck in the 70's..$400.00 ● '46 - '48 Ford 59ab cast iron heads....$35.00 ea./$65.00 for the pair. ● '46 - '48, good used 59 crankshafts. Mains measure from 2.4880" to 2.4965" and rods measure from 2.1280" to 2'.1370". $85.00 each ● '35 original aluminum intake manifold.....$65.00 ● '36 original aluminum intake manifold....$65.00 ● '37 - '39 original aluminum intake manifold... $65.00 ● '34 original aluminum intake manifold. Has been bead blasted. ..$80.00 ● '35 front engine mounts/water outlets for lower radiator hose connections. $60.00/pr. ● '35 - '36 center of X member. This is not the complete X member, just the very center piece that is riveted in place. $50.00 ● set of water pump block off plates for use on '37 to early '38, 21 stud engines when engine is going into a '33 to '36 Ford with 21 stud heads and water pumps mounted on front of heads... $45.00/set ● '35 - '48 flathead engine oil pans.... $70.00/ea. ● '35-'36 emergency brake hand levers.... $50.00/ea. ● '35-'36 cowl vent door $35.00 ● '35 - '48, 4.11:1 ratio ring and pinion gear sets, 10 spline pinion, matching numbers, in excellent used condition. Some folks prefer this ratio gear set to use in their 2 speed Columbia rears.... $100.00/set ● '35 3 speed transmission. Complete, low mileage item with nice gears. Includes top shifter mechanism with original shift lever. All internals are in excellent condition... $300.00 ● '36 steering column complete with steering wheel, light switch rod & horn button, column drop w/working lock cylinder & key, nice column tube, and steering gear box with no play...all in good working condition for $450.00 ● '35-'36 touring sedan trunk lid. Has original black paint, and in very nice original condition, with no rust ever... $65.00 ● '35 to '37 pickup truck left, drivers side door. This door will also fit the larger trucks that use the same size cab. In good condition..$275.00 ● Kari-Keen Accessary Car Trunk assembly that will fit '33 to '36 slant back tudor/fordor sedans, convertable sedans, and phaetons. This is the complete accessary attachment trunk with all necessary pieces and hardware to attach to your vehicle. I paid a lot of $'s for this trunk to use on my car during tours, but have since found a trunk that will sit on and attach to my luggage rack and have now decided to sell this Kari-Keen Trunk....$1700.00 obo PM or email me if interested in any of these parts, or if you have any '35 parts you might want to trade for any of these parts. Prices shown do not include cost of shipping Offering free delivery for any of these parts to Fitchburg, Ma., Rhinebeck, NY, Jalopy Showdown in York Springs, Pa, NSRA Street Rod Nats in York, Pa, Spring/Fall Carlisle, & Fall Hershey swap meets/car shows, Early Ford V8 Club/America meet in Chantilly, Va, and possibly other swap meets/car shows on the East Coast/Mid Atlantic area.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 04-24-2017 at 07:54 PM. |
04-04-2017, 12:07 PM | #2 |
Re: Early Ford V-8 Parts 4 Sale
Bttt
04-11-2017, 10:00 AM | #3 |
Bttt
04-19-2017, 08:20 PM | #4 |
Bttt
04-22-2017, 11:53 PM | #5 |
Bttt
05-02-2017, 08:57 AM | #6 |
05-12-2017, 09:44 AM | #7 |
Bttt
05-24-2017, 08:31 AM | #8 |
Bttt
06-24-2017, 09:37 PM | #9 |
Bttt
06-28-2017, 01:39 PM | #10 |
Bttt
07-01-2017, 11:13 PM | #11 |
Bttt
07-30-2017, 04:37 PM | #12 |
Bttt
Note: Some items on original list have been sold, but due to changes made to this website, the original listing can not be edited to reflect this. ● 36 column drop.....SOLD ● 37 column drop.....SOLD ● 35-36 front wish bones....SOLD ● 32-early 35, 56 tooth aluminum timing gear....SOLD ● 37-41 perch pins....SOLD ● Ford Script Battery...SOLD
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-15-2017 at 11:44 PM. |
