Old 10-08-2013, 05:23 PM   #101
dono50
dono50's Avatar
Send a message via MSN to dono50
Default Re: 8BA block leaking water from exhaust port ?
Originally Posted by zzlegend View Post
dono50. Just curious if you are back up and running?
Finally got the engine started today and no leaks, I'm elated!
dono50 is offline   Reply With Quote
Old 10-08-2013, 05:57 PM   #102
GOSFAST
GOSFAST's Avatar
Hi Bob, you had doubts???
Thanks, Gary in N.Y.
P.S. Never a single doubt here, like I stated earlier, "excellent job"!!
GOSFAST is offline   Reply With Quote
Old 10-08-2013, 07:08 PM   #103
dono50
dono50's Avatar
Hi Gary,
Thanks for you technical and moral support.
I had some head alignment problems last week but redrilled 2 head bolt holes and used helicoils.
Would not start last week and a compression test showed 2 adjoining cylinders with low compression because 2 head bolts were off center.
After resolving that issue, it started, no problem, and sounds good.
Back to body work which is a lot less stressful.......Bob
Old 10-08-2013, 07:27 PM   #104
Vergil
Vergil's Avatar
Thanks for the update Bob ......
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 10-08-2013, 07:47 PM   #105
Binx
Could you elaborate a little more on this issue? Are you saying you re-drilled holes in the head to align the gasket? What type of head?
Lonnie
Binx is offline   Reply With Quote
Old 10-08-2013, 09:35 PM   #106
dono50
dono50's Avatar
Lonnie,
I had 2 head bolts (#1 and #3) broken studs that were drilled off center and the head would not seat properly resulting in low compression on 2 cylinders
I redrilled and installed helicoils, not perfect, but close enough to get the job done....
Old 10-08-2013, 09:38 PM   #107
dono50
dono50's Avatar
Vergil,
Your cutaway was very helpful.
Thanks, Bob
Old 10-08-2013, 09:46 PM   #108
zzlegend
zzlegend's Avatar
Nice going dono. Glad to hear this. Mark.
zzlegend is offline   Reply With Quote
