Old 08-31-2020, 06:17 PM   #1
shew01
shew01's Avatar
Default Can anyone recommend a rear hub puller?
Can anyone recommend a rear hub puller? My 1931 Victoria has one rear hub with a groove, and one rear hub with a ring. I would prefer to have one tool that does both designs. A friend of mine in our club has a heavy duty antique puller that I can borrow, but I don't want to be a bother to him. I'd like to find something that I could just keep in the garage for when I need it.
I saw this on Amazon.com, but I don't know if it would hold up very well or not. It may not even fit over the hub.
https://smile.amazon.com/OEMTOOLS-27...%2C152&sr=1-11
Old 08-31-2020, 06:28 PM   #2
wmws
Default Re: Can anyone recommend a rear hub puller?
That one on Amazon is NOT what you need. Look up universal 3 jaw puller. You need something like that.
wmws is offline   Reply With Quote
Old 08-31-2020, 06:38 PM   #3
wwirz
You will not need the puller often. See if you can borrow one. Club members have unusual tools that you can borrow. If you were in my club or nearby, I would let you borrow my puller
wwirz is offline   Reply With Quote
Old 08-31-2020, 06:45 PM   #4
Synchro909
Synchro909's Avatar
I have a puller that I bought at a swap meet so I have no idea what brand it is. It even looks as though it could be home made. It works on both the grooved and ridged hubs except on out of 8 I have that has a larger diameter in the groove.
The puller is two pieces that form a cylinder and after you put them around the groove (or ridge), a sleeve goes over them to hold them together and a bolt in the end is tightened to pull the hub. There has been only one hub that I couldn't pull with that puller and that was because someone had used loctite on the taper (GRRRR!).
Old 08-31-2020, 06:52 PM   #5
shew01
shew01's Avatar
I appreciate the sentiment. However, as I posted above, I can borrow one from a friend in our Model A club, but I don't want to be a bother. It would be handy to have one just sitting on the shelf in case (i.e., when) it is needed.
Old 08-31-2020, 06:54 PM   #6
shew01
shew01's Avatar
I started out with one of those. Mine kept slipping off of the hub, which is why I ended up borrowing from a friend a while back.
Old 08-31-2020, 06:58 PM   #7
shew01
shew01's Avatar
I saw this one online, but it looks a little pricey, and it apparently would only work on one of my hubs, since I have one ring hub and one groove hub.
http://www.vintageprecision.com/prod...ers/index.html
Old 08-31-2020, 07:12 PM   #8
1955cj5
1955cj5's Avatar
This is the one I use. Works on Model A's just fine as the picture shows....
https://www.kaiserwillys.com/heavy-d...86-jeep-willys
And who knows, you may buy a jeep someday...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-31-2020, 07:17 PM   #9
Bob C
If you look at the info it won't work on the protruding ring style hub.
Old 08-31-2020, 07:20 PM   #10
shew01
shew01's Avatar
Actually, that is somewhat similar to the one I borrowed from my friend. Only his was (believe it or not) a little more heavy duty. I don't think I've ever seen a wheel puller as big as his. LOL
Old 08-31-2020, 07:20 PM   #11
Patrick L.
Patrick L.'s Avatar
Bratton's has them, take your pick. You can get both individual pullers cheaper than the universal.
Old 08-31-2020, 07:51 PM   #12
shew01
shew01's Avatar
Thanks. I saw the universal one on Bratton’s before I posted. Have you ever used one of them? If so, what are your thoughts on them? Will they last well?
Old 08-31-2020, 07:56 PM   #13
Jack Shaft
If your handy you can run one up..
Old 08-31-2020, 08:02 PM   #14
Y-Blockhead
Y-Blockhead's Avatar
Mitchell Manufacturing makes one that works on both style hubs. As with all of their products it is top notch. ~$100 https://mitchelloverdrives.com/mitchell-hub-puller/
Old 08-31-2020, 08:45 PM   #15
shew01
shew01's Avatar
Hmmm... That looks like the universal one that Bratton’s sells.
Old 08-31-2020, 08:46 PM   #16
1930-Pickup
I love my Model A hub puller.
It was made by Blue Point Tools around 1933 (tool #429).
You can have one too, but you'll have to keep an eye out for one on eBay.
When I bought mine about four years ago, I was the only bidder.
65 USD I think it was.
File Type: jpg Blue Point Snap On puller No 429 - 1933 Catalog page 82.jpg (83.7 KB, 56 views)
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-01-2020, 06:20 AM   #17
Patrick L.
Patrick L.'s Avatar
No, I've not used that puller. If its a Mitchell it should be good.
I use other pullers if needed. I can't remember the last time I've used one on an A. The hubs usually come off with a tap of the axle.
Old 09-01-2020, 08:27 AM   #18
Licensed to kill
Licensed to kill's Avatar
While reading this thread I was thinking "I will just make a collet type puller" but my initial conception (in my head) was a bit different than that blue point one. Of course, the blue point one is a much better design than what I had come up with so I will make one based on yours. Thanks for sharing. Love it.
Licensed to kill is offline   Reply With Quote
Old 09-01-2020, 10:09 AM   #19
katy
katy's Avatar
I have and use one like this:
https://www.amazon.com/Cal-Van-Tools...972767&sr=8-10
Works excellent.
Old 09-01-2020, 11:06 AM   #20
Ernie Vitucci
Good Morning...I have Vintage Precision's thermostat housing and it is superb! So I imagine that their hub puller would be as well...particularly as it is an improvement on K.R. Wilson's design...and they were pretty much the top of the heap, back in the day...Ernie in Arizona
