Old 06-25-2019, 06:28 PM   #21
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Ford-o-matic converter position
A member of the other forum found a SERVICE LETTER pertaining to the flex-plate issue. There has to be a later SL describing going with the reinforcing rings usage.
http://forums.y-blocksforever.com/Topic146468.aspx
File Type: jpg Flexplate- B7A 6375-A - SL P-348 JUNE 12, 1957.jpg (38.7 KB, 12 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 06-26-2019, 03:48 AM   #22
KULTULZ
KULTULZ's Avatar
Question Re: Ford-o-matic converter position
Got to wondering about fastener length-
6379 BOLT – FLYWHEEL TO CRANKSHAFT –
54/ A,S AT- B8A 6379-A – 7/16”- 20 X 11/16” – hex head – self locking
This PN (1958) is a service upgrade for whatever reason. So there is more going on than just the flex-plate design upgrade and retro-fit to the 55 and 56 models.
Of course this PN is from the 49/59 MPC and all previous info was deleted. Also need a period CHASSIS CATALOG to figure it out.
Old 06-26-2019, 10:40 AM   #23
KULTULZ
KULTULZ's Avatar
Post Re: Ford-o-matic converter position
Originally Posted by dmsfrr View Post
... I can't find a diagram in the book I just looked in.
Whether the rings are one one side of the flexplate or the other won't change the overall distance to & thru the crankshaft flange. But if the bolts are too long they will catch on the back of the block.
The reason(s) it is not shown in the ILL is most likely as a result of a series of changes regarding design. It would be confusing to have a updated sequence off ILL's showing that detail.
As for placement of the rings, it would be crucial to the final position of the plate against the torque convertor housing.
In later years TEXT, a note was usually attached to refer to a SERVICE LETTER and/or TSB so and so. Being the MPC is FINAL ISSUE (1964), a lot of information was deleted.
- WHY IS IT ... -
