Old 12-01-2019, 01:24 PM   #1
poolplayer1
Default 55 with a 302 engine/ Timing question.
I was checking the timing on my 302 engine yesterday and noticed that I have the timing at 10 degrees before top dead center. This is a complete rebuilt engine. I have heard of guys setting the time at TDC on an engine like this so I thought i would ask you guys what the timing should be set at.
Should I set it to tdc or just leave it at 10 btdc? Thank you for your help.
poolplayer1 is offline   Reply With Quote
Old 12-01-2019, 04:29 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 55 with a 302 engine/ Timing question.
The timing may be just fine where it is, especially if it's been running without noticeable problems.
Assuming it has the original distributor & ignition system, look up the tune-up specs for the year of the engine and follow them.
Knowing the year of the engine and any performance parts changes beyond stock will be helpful.
dmsfrr is offline   Reply With Quote
Old 12-01-2019, 04:51 PM   #3
scicala
scicala's Avatar
My old Ford Motorcraft specs manual says 6 degrees BTDC for all 302's from '68 through '72. I don't have any specs beyond that year. I'm sure 10 degrees is just fine unless you get spark knock under load.
Sal
Old 12-01-2019, 06:28 PM   #4
40cpe
40cpe's Avatar
It is important to check total advance as well as initial. IIRC, total mechanical and initial should be 36-38 degrees. When the vacuum is connected it can be around 50 degrees. I ran a 302 on regular gas for many years with good mileage in a '40 coupe. Before ethanol I would always get 19-20 on the road running 70 or above.
40cpe is offline   Reply With Quote
Old 12-02-2019, 11:44 AM   #5
poolplayer1
Thanks to all for your response. The engine is a 1968. I might try to change to 6 degrees to see if there is any difference in performance.It is running ok at 10 but will try 6 just for the heck of it. I am also going to check the total timing to see where its at.
Old 12-02-2019, 01:15 PM   #6
scicala
scicala's Avatar
If it runs good at 10 degrees, 6 degrees won't be any better and maybe even a very slight drop in fuel economy.
Sal
Old 12-04-2019, 08:38 PM   #7
50fordcoupeman
50fordcoupeman's Avatar
My 302 is a stock 1971 and I believe it is set at 10 degrees. It runs strong with no overheating or pinging issues.
50fordcoupeman is offline   Reply With Quote
