11-07-2017, 06:54 PM | #1 |
Installing glass in Rear window of Pickup...?
Ive had the glass cut, and worked over the original trim ring that goes inside
The cab. My question is .... On the four corners, there are holes in the trim ring, but No tabs in the cab for them to bolt to. Is there a clip that holds the glass to the trim ring? I haven’t ordered the machine screws and nuts yet. |
11-07-2017, 07:00 PM | #2 |
Re: Installing glass in Rear window of Pickup...?
Should be separate metal corners- Vendors will have them or do you have them;like an "L" bracket.DO NOT over tighten you will break the Glass!!!
www.whidbeymodelaclub.com Last edited by Gary WA; 11-07-2017 at 07:13 PM. |
11-07-2017, 07:40 PM | #3 |
Thanks Gary. I see them in Bratton’s and Snyders. Have to order the screws too.
11-07-2017, 09:45 PM | #4 |
Think about putting in a sliding back window. they were Ford accessories starting in 1935. they do a fine job in keeping the cab cool.
11-08-2017, 01:00 AM | #5 |
