Old 06-07-2020, 04:34 PM   #1
Cape Codder
Cape Codder's Avatar
Default Tie Rod End Installation
Bought NEW Pitman Arm because Ball end was worn and have shaking in front end. Also bought new bolt for the Pitman Arm. With approx. 225 in. of torque on bolt nut Pitman Arm is moving fore and aft a SSSSSLLLLight bit. Sector Shaft looks fine although don't know what a good shaft measures to?
Have tried to assemble any way BUT CANNOT get back plug of drag link threaded into drag link. WHAT is the SECRET in installing this plug?
Does anyone have any thought on either PROBLEM?
Cape Codder is offline   Reply With Quote
Old 06-07-2020, 05:02 PM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Tie Rod End Installation
Is the pitman arm lose on the sector shaft or is there play in the steering box?
As for the drag link plug, mine was a real bear to get started. Maybe get some help, someone with BIG arms... maybe your MIL?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 06-07-2020, 06:07 PM   #3
Cape Codder
The Master Cylinder We adjusted the end play and as far as we can see it is NOT moving.
Old 06-08-2020, 06:23 AM   #4
aermotor
[QUOTE=Cape Codder;1896631]Bought NEW Pitman Arm because Ball end was worn and have shaking in front end. Also bought new bolt for the Pitman Arm. With approx. 225 in. of torque on bolt nut Pitman Arm is moving fore and aft a SSSSSLLLLight bit. Sector Shaft looks fine although don't know what a good shaft measures to?
I have found that the steering box mount bolts to frame holes slightly elongated to trick you into thinking it is the pitman arm to shaft movement.
John
aermotor is offline   Reply With Quote
Old 06-08-2020, 06:27 AM   #5
1931 flamingo
1931 flamingo's Avatar
Has to be TIGHT, NOT in. lbs........................
Paul in CT
Old 06-08-2020, 10:18 AM   #6
The Master Cylinder
Paul in CT
Well 225 in. lbs. is ~19 ft. lbs.
The Master Cylinder
Last edited by The Master Cylinder; 06-08-2020 at 10:37 AM. Reason: Added punctuation.
Thread Tools
Display Modes
