09-22-2018, 02:11 AM | #1 |
Master sylinder for 1952 Mercury
Hi!
I have a 1952 Mercury Custom. To upgrade safety, I would like a dual bowl(?) master cylinder. I have searched the web as good as I can, but haven't been able to find one. The bore is 1". Anyone have any idea? (Please ignore my bad English, I'm from Norway) Rune |
09-22-2018, 03:39 AM | #2 |
Re: Master sylinder for 1952 Mercury
Personally I'd just fit a new stock type, but if you want a 1" dual, a 67 Mustang is a dual with a 1" bore. Rockauto have Merc or Mustang cylinders and from my experience are good for international shipping.
The brake pipe fittings require one with a 1/2"-20 thread and one with a 9/16"-18 thread. You might need external residual valves. Mart. |
09-22-2018, 06:51 AM | #3 |
Just about any mid 1960's vehicle (Ford or GM ) with DRUM/DRUM dual master cylinders can be adapted.
They generally have residual valves built in. This is one example--- https://www.napaonline.com/en/p/NMAM39495 Or this----- https://www.napaonline.com/en/p/NMAM2056
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-22-2018 at 07:05 AM. |
09-22-2018, 09:44 AM | #4 |
I put discs on y 52 merc but before I did that I bought a 67 mustang master cylinder (for drum brakes) and was going to adapt that as it bolts into the existing holes. You can use the Speedway catalog to find parts adapt the actuating rod. Never used it and still have it if you're interested.
Rob |
09-22-2018, 10:17 AM | #5 |
I've seen videos on youtube on updating an older car to newer style dual circuit master cylinder. I just went with a new original style for my 52 from Napa.
https://www.youtube.com/user/roosty6/videos |
09-22-2018, 10:29 AM | #6 |
After you have it installed and bled, open a rear bleeder screw and see if the car will stop with the front brakes (in a safe place). Then repeat with a front bleeder open. I suspect that at least some of these conversions have never been tested and will result in total loss of braking in event of a blown hose. |
