Old 11-30-2012, 10:15 PM   #1
myaddress2020
myaddress2020's Avatar
Default hot riveting
hello all
i wonder if anyone out there has ever hot riveted new "roller tracks" on a model A, brake, back plate? the tracks come with a jig to hold one side of the rivet.
the way i understand it i could use a propane torch to get the rivet red hot, then pick up a lump hammer and beat the rivet into a mushroom, but i didnt know if i should have a tool to hit the top of the rivet, with a mushroom shape in it.
Vince
myaddress2020 is offline   Reply With Quote
Old 11-30-2012, 10:34 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: hot riveting
Tool for the hot end not needed, heat cherry red and peen it.
Old 11-30-2012, 11:13 PM   #3
myaddress2020
ok i gotcha.
im thinking its better to heat the rivet seperated from back plate and when its red, grab and slide the plate with roller track over the top of the rivet. this way i wont heat the plate and track unnecessarily. will the rivet have expanded stopping me from doing that?
Old 11-30-2012, 11:42 PM   #4
jkeesey
jkeesey's Avatar
if you concentrate your heat on the rivett it will not transfer to the backplate. no worries heating them together. i use the rivett tool in my impact gun and they come out looking like original.
jkeesey is offline   Reply With Quote
Old 12-01-2012, 11:40 AM   #5
H. L. Chauvin
If no impact tool available, Model A vendors sell a hand held Rivet Upset Tool that one hits with a ball pein hammer to provide a neat round head.
H. L. Chauvin is offline   Reply With Quote
Old 12-01-2012, 12:45 PM   #6
Ca. Kid
Ca. Kid's Avatar
I found that a propane torch is not sufficient. You need oxygen/acetylene. The backing plate acts like a big heat sink. Also if your holes are the proper size you cannot heat the rivet then insert it into the backing plate. The rivet expands just enough to prevent that.
Ca. Kid is offline   Reply With Quote
Old 12-01-2012, 04:54 PM   #7
myaddress2020
i think i just found that out about the propane. my uncle is a heating guy and he uses acetylene to sweat pipe. there isnt an oxy cylinder with it. just the ac i guess.
Old 12-02-2012, 07:59 PM   #8
myaddress2020
does any one know if you should use acetylene alone or with oxygen when hot riveting roller tracks on?
Old 12-02-2012, 08:20 PM   #9
wrndln
If you use only acetylene, you will get lots of smoke, particles floating around and a very cool flame. You have to have oxygen to get a very hot flame. I think what your uncle was using was Mapp gas. It is similar to propane, but produces a hotter flame (no additional oxygen needed). I am not sure Mapp gas would produce a hot enough flame to get the rivet cherry red.
Rusty Nelson
Old 12-03-2012, 09:23 AM   #10
TD
TD's Avatar
Definitely oxy/acetylene to heat rivets cherry red, on the parts to be assembled. Use two people - one to work the torch, one to mushroom the rivet. Do it in two steps instead of all at once for a more controlled process.
TD
TD is offline   Reply With Quote
Old 12-03-2012, 07:57 PM   #11
PetesPonies
PetesPonies's Avatar
You really can't burn just acetylene. It's not hot enough and it will choke you . . dirty soot everywhere.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 12-03-2012, 08:21 PM   #12
MikeK
MikeK's Avatar
Just to clarify "burning", you will get a yellow, sooty flame from propane and mapp as well as acetylene if burned in free air with no added air or oxygen in the mix. The propane and mapp torches use the venturi principle to suck air into the mix. There are lots of acetylene/air torches out there too, and they mix in air the same way, giving an adiabatic mix that produces a nice blue flame, about 4,350F, much hotter than mapp. I have one attached to a prestolite tank, used it for years for brazing work on heavy silver. It will make a steel or wrought iron rivet bright orange quickly and easily. What you will not get from any air/fuel torch is the pinpoint inner flame needed for puddle control in welding. That requires pure oxygen in the mix.
Mechanical engineering 101: If you put an adjustment knob, screw, bolt, or tolerance specs on something, some people will immediately fiddle with it. If you mark it DO NOT TOUCH everyone will mess with it.
MikeK is offline   Reply With Quote
Old 12-04-2012, 09:41 AM   #13
myaddress2020
did the job yesterday with my friends oxy acty torch. worked fine. i think mike here is right, you can do it with just acetylene. the oxy is needed if you are welding and need that pretty puddle. thank you everyone.
Vinny
Old 12-04-2012, 10:09 AM   #14
Mikeinnj
Mikeinnj's Avatar
I have been using this inexpensive Bernz=O-Matic oxygen/map gas torch for years for welding brazing and heating rivets cherry red, Works like a dream using inexpensive replacement cylinders.
http://www.bernzomatic.com/item.html?id=30
Mikeinnj is offline   Reply With Quote
