07-28-2013, 11:53 AM | #1 |
'53 flathead 6v Pertronix conversion
My dad has a '53 wagon, all stock. We want to convert it to Pertronix.
It's still 6v positive ground with a generator. Will the original coil work? Will Pertronix work ok with the generator? Has anyone done this swap and can take a pic of the wiring or explain it better because the directions are a little confusing on how to wire it to the coil/ignition. Thanks! |
07-28-2013, 01:02 PM | #2 |
Re: '53 flathead 6v Pertronix conversion
I would suggest installing a new set of napa echlin contacts and living happily ever after.
Positive ground six volt PERTRONIXS have some issues with voltage issues, and voltage spikes etc........ |
07-28-2013, 01:32 PM | #3 |
Is the Napa contacts just a set of ignition points or??Could you explain??
07-28-2013, 01:44 PM | #4 |
I have a '52 F1 - 6 volt - positive grd. Installed a Pertronix Ignitor distributor kit with one of their Flamethrower coils about7 years ago. I love it!!! Installed the coil first and that alone was a big improvement - then put in the Pertronix Ignitor kit - #1283P6 - and it runs like a top!!
07-28-2013, 04:41 PM | #5 |
Bruno, can you take a pic of how it's wired to the coil, please? Thanks!!!
07-28-2013, 05:52 PM | #6 | |
Yes buy the echlin heavy duty set with the condenser. |
07-29-2013, 08:02 AM | #7 |
Nothing different or special about coil to dist. wiring - wire pos. side of coil to grd. - neg. side to distributor. Then, of course, the coil center wire is connected to the distributor cap center terminal. You may want to call Tony Neisz at Philbin Rebuilt Products - 1-800-867-7301 if you still have questions on Pertronix dist. or coil products.
07-29-2013, 08:40 AM | #8 | |
This is not correct. With a stock Pos Gnd system the feed wire goes to coil (-) and the coil (+) side goes to the distributor. With Pertronix, the feed wire goes to the Pertronix Unit, then one wire from Pertronix to coil input (-), and the other side of coil (+) goes to ground. |
07-29-2013, 01:11 PM | #9 |
This was sent to me from Pertronics, I went with a chevy dist conversion
(points type) from Bubba's From Pertronics: double click for larger pic If you have a o.d. trans you need that resistor in the o.d. kickdown wire. |
07-29-2013, 08:20 PM | #10 |
An observation from one who's been there, done that: Point will always get you home, while Pertronix maybe not so much. Just sayin'.
07-29-2013, 09:46 PM | #11 |
Guess I'm just lucky or something but I've never had any problems with my Pertronix Ignitor set-up - still have the old points, etc. but do not carry them with me in the '52.
My records show I put the Pertronix system in in 2006 - either July or August. Again - just keeps on ticking and taking a licking (like the old Timex???) |
07-29-2013, 10:14 PM | #12 |
No luck about it … they make a quality deal.
I use to keep a fleet of 18 ex U haul F 600’s running for a friend of mine. They all had old Pertronix conversions with who knows how many miles ….. In 6 years I only had one old one fail and iv never had a new one go bad. The best thing about them is the points screw right back in if need be …. Just keep them in the glove box w condenser and the wire to run to the coil. |
