Old 03-03-2020, 08:09 AM   #1
rockfla
rockfla's Avatar
Default Flathead Re-builders....Do You
Question of the day?
Had a head gasket let go on a sort of "tired", good running flathead (pushing coolant out the back of the head). Pulled the heads and no evidence of any cracks. Having the heads checked now and IF good having them "decked". The question is.......Since the block is not getting decked......do you use any kind of "sealant" product around the water ports on the block and heads with the newer graphite head gaskets???
Old 03-03-2020, 08:50 AM   #2
jimTN
Default Re: Flathead Re-builders....Do You
If you used a steel or copper gasket and coated it with a sealer like "copper coat" you would not have a problem.
Old 03-03-2020, 11:29 AM   #3
supereal
supereal's Avatar
Almost all cylinder heads show some warping and should be checked with a good straight edge. At our shop we resurface both the gasket surface of the heads, and the deck of the block on each job. With good quality head gaskets, no gasket sealer should be necessary. It is a good practice to install a good sealer to the coolant. When I was working for a Ford dealer years ago, each "authorized rebuilt" engine included a bottle of sealer.
supereal is offline   Reply With Quote
Old 03-03-2020, 01:21 PM   #4
Ggmac
I still spray the gasket , both sides with aluminum paint . And use a thin layer of grease on the surface . Never had any leaks and I've built dozens if not more when I was employed.
Old 03-03-2020, 02:25 PM   #5
Ol' Ron
Ol' Ron's Avatar
Torque to 45 ft 33 heat cycles. Over torquing warps the BLOCK!!
Old 03-03-2020, 05:58 PM   #6
cadillac512
cadillac512's Avatar
No. A graphite gasket ("Best" brand gaskets are a very good choice) needs no sealer.Resurfacing the heads is a VERY good idea.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
cadillac512 is offline   Reply With Quote
Old 03-03-2020, 06:12 PM   #7
35fordtn
35fordtn's Avatar
I use sealer on all gaskets EXCEPT the graphtite best brand gaskets. They are about as good as it gets.
Old 03-03-2020, 07:16 PM   #8
Hal Beatty
Hal Beatty's Avatar
Read Best Gaskets recommendations for their Graphtite head gaskets... use a sealer.
https://bestgasket.com/about-our-products/
Scroll down, it's on the right side.
Hal Beatty is offline   Reply With Quote
Old 03-03-2020, 08:01 PM   #9
Tinker
Tinker's Avatar
Use a spray sealer. Not a tube.
Old 03-04-2020, 02:40 AM   #10
deuce lover
deuce lover's Avatar
Hylomar Blue in a aerosol can might work. flatheadmurre(member here) advised me to use it and it worked.
deuce lover is online now   Reply With Quote
Old 03-04-2020, 07:50 AM   #11
rockfla
rockfla's Avatar
Ole' Ron
33 Heat cycles......meaning run the engine to "normal" operating temperature and let cool, RE-TORQUE at 45 for 33 straight times??
Old 03-04-2020, 08:00 AM   #12
flatheadmurre
flatheadmurre's Avatar
I think OlīRon means 3 heat cycles...computer hickup...
Old 03-04-2020, 09:14 AM   #13
JSeery
JSeery's Avatar
Ole' Ron
Ya, that is 3 as in three, LOL.
Old 03-04-2020, 10:08 AM   #14
Ol' Ron
Ol' Ron's Avatar
I can't see the screen sometimes. Probably won't be able to do this much longer.
Old 03-04-2020, 10:20 AM   #15
JSeery
JSeery's Avatar
Hang in there Ron, we got your back!
Old 03-04-2020, 08:06 PM   #16
Ol' Ron
Ol' Ron's Avatar
Thanks JS
Old 03-04-2020, 08:13 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Hey hey......If Ron wants to check it 33 times, the torque will most-assuredly be precisely ON THE MONEY! DD
T5 W/TORQUE TUBE
LAZINESS is the art of RESTING...BEFORE you get tired!
