Old 12-06-2018, 12:30 PM   #1
cederholm
cederholm's Avatar
Default Identifying a model A frame
I know it's here, but I can't seem to find it. How can I tell a 28/29 frame from a30/31 frame? ...from the bare frame alone.
Thanks!
cederholm is offline   Reply With Quote
Old 12-06-2018, 12:56 PM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: Identifying a model A frame
Check the serial number on the frame first, if there is one.
David Serrano
California Travieso is offline   Reply With Quote
Old 12-06-2018, 01:02 PM   #3
Steve Plucker
Here you go...
http://www.plucks329s.org/pdf/frame/..._Assembly2.pdf
Have fun.
Pluck
Old 12-07-2018, 09:28 AM   #4
cederholm
cederholm's Avatar
Thank you!
Old 12-07-2018, 11:59 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Steve Plucker View Post
Awesome study, Pluck. Lots of good info. Thanks for posting the link.
Old 12-07-2018, 06:01 PM   #6
flatford39
Look at the front crossmember. The radiator supports are different. 30 31's are lower.28 29's are even with the frame rail.
flatford39 is offline   Reply With Quote
Old 12-08-2018, 12:58 PM   #7
john charlton
john charlton's Avatar
28/29 frames are drilled both sides for RHD and LHD for the steering box.30/31 frames are mostly drilled on one side depending whether the vehicle was built RHD or LHD .However there are 30/31 frames that are drilled both sides there is one under my P/U which also has the early handbrake cross shaft . This early 30/31 frame is in the minority and does come with the correct "low dip" rad mount area . If you see a frame which at first glance has only one steering box hole it is definately 30/31.
John in Suffolk County England.
john charlton is offline   Reply With Quote
