04-18-2011, 10:18 PM | #1 |
Rear Housing Race Repair Kit
Would any of you happen to know the radial thickness of the "Housing Race Repair Kit" listed in the Snyders Catalogue of 2010, page A-93 under part# A-1225-SL ?
Could a person use a bearing designed "Speedy Sleeve" for the rear axle housing, or would they be too thin for prolonged service ? I am not familiar with the radial thickness of the common "Speedy Sleeve" either. Would either be hardened in any way, or just a high carbon steel ? |
04-18-2011, 10:50 PM | #2 |
Re: Rear Housing Race Repair Kit
This may be helps you!
Specifications: Type: . . . . . . . . . . . . . . . . . . Three quarter floating Material . . . . . . . . . . . . . . . Special Ford carbon manganese steel Gear ratio (gear teeth: ring pinion) 3.78:1 (34-9) Early '28's: 3.7:1 (37-10) T rucks: 4.11:1 (37-9) ~ 10,000 28-29 Roadsters: 3.54:1 (39-1 1) Pinion bearing . . . . . . . . . . Double taper roller type Bearing cup . . . . . . . . . . . . Timken 28317 Bearing . . . . . . . . . . . . . . . Timken 28156 Ring gear . . . . . . . . . . 8.4" pitch diameter, 1-3/16" wide teeth Axle shaft . . . . . . . . . . . . . . 1-1/8" diameter; 1.128 to 1.130" at wheel bearing Dimension from housing flange to bearing shoulder in axle housing: Before 1929 . . . . . . . . . . . . 1.370 to 1.372" After 1929 . . . . . . . . . . . . . 1.365 to 1.367" Rear wheel bearing . . . . . . O.D. Of axle housing race 2.061 to 2.0635" I.D. Of wheel hub . . . . . . . . 3.188 to 3.190" : Max wear 3.185" Axle and drive shaft seal . . . CR 10926 Rear axle seal . . . . . . . . . . CR 20112, Victor 49024 Differential lubricant . . . . . . 600W |
04-19-2011, 12:27 AM | #3 |
The repair sleeve is quite thick. I'm guessing because I put mine in a long time ago. To me it was about 4 to 5mm thick. It's size is the difference between the "A" and V8 bearings OD.
04-19-2011, 05:09 AM | #4 |
The speedisleeve would be too thin to work as a bearing race.
04-19-2011, 09:16 AM | #5 |
