Old 05-02-2018, 03:35 PM   #1
BL
Default Generator Air Scoop ? ?
I was told years ago that a so called generator air scoop was a rare item.
Have any of you seen one of these ?
I was not able to post a photo.
Thanks, barners !
BL is offline   Reply With Quote
Old 05-02-2018, 03:46 PM   #2
rocket1
Default Re: Generator Air Scoop ? ?
Yes they were available years back,aftermarket,took the place of the band that covers the brushes.
rocket1 is offline   Reply With Quote
Old 05-02-2018, 04:25 PM   #3
Charlie Stephens
This is probably what you are thinking about. Excuse the dust.
Charlie Stephens
Old 05-02-2018, 04:47 PM   #4
JOHN CT
JOHN CT's Avatar
I had one of those when l bought my A. I do understand the theory behind it to keep the gen cool, but I think it’s last place that I want any dirt or road grime in it. Right now I think it’s in my miscellaneous pile.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-02-2018, 05:04 PM   #5
Bob C
The vendors have them.
Bob
Old 05-04-2018, 12:03 PM   #6
BL
Thanks guys,
Is there a vendor that I can buy one from ?
Old 05-04-2018, 12:18 PM   #7
Bob C
Originally Posted by BL View Post
Thanks guys,
All the vendors I looked at had them.
Bob
Old 05-05-2018, 08:18 AM   #8
Curtis in MA
Brattons Part #: 15410
Curtis in MA is offline   Reply With Quote
Old 05-05-2018, 12:44 PM   #9
Badpuppy
Waste of money, imho. But I would install it "backwards", screen to rear. Airflow would
then add to convection flow, not hinder it.
Henry didn't think it necessary, and neither did anyone else.
Old 05-05-2018, 06:09 PM   #10
Bob-A
Bob-A's Avatar
Thumbs up Re: Generator Air Scoop ? ?
Auto makers or at least the generator makers. Realized that solid un-vented
generator bodies retained a lot of heat. Vented end caps on the genny bodies became standard later in the 30's. I run a Delco-Remy 946-C (1935 Chevrolet) truck generator on my '31 "A" roadster. The cast iron end caps
are designed with numerous air slots in them. I like goofy old bolt on era
accessories. If I ever run a Ford genny again I'll definitely use the scoop.
Bob-A
Bob-A is offline   Reply With Quote
Old 05-06-2018, 08:56 AM   #11
Badpuppy
To each his own. I have one I'd swap even for a proper cover band.
Old 05-06-2018, 10:22 AM   #12
Purdy Swoft
Purdy Swoft's Avatar
Bob -A , understands the benefits of generator cooling ! Later generators had a fan behind the pulley and slots in the housing and end plates for cooling . Model A generators were good for their time but had no cooling apparatus at all . The accessory cooling band does a good job of cooling the generator . Not only does the air scoop keep the commutator cool , it also allows some of the dust that wears off the brushes to be blown out through the bottom of the generator band . I have used the cooling bands for years and know that they can extend generator life expectancy .
Old 05-07-2018, 11:33 AM   #13
burner31
burner31's Avatar
About $18, most vendors
Keith
Shawnee OK
'31 SW 160-B
