04-23-2016, 02:52 PM | #1 |
compression ratio
what a good compression ratio for a street engine with out having problems with it
04-23-2016, 03:34 PM | #2 |
Re: compression ratio
Please put this in perspective.
What engine Car Useage Karl |
04-23-2016, 03:46 PM | #3 |
flathead ford v8 in a model a model 59 with 125 over bore and 4 1/4 stroke crank
04-23-2016, 04:26 PM | #4 |
I, personally, would want no more than 9:1.
You have a large flathead at about 292 cubic inches, if my math skills are correct. It may be a bit difficult to obtain a ratio like that. Do your homework on combustion chamber volumes on various heads to make a good decision and head selection. JMO Jim |
04-23-2016, 04:35 PM | #5 |
they say with a 74 cc head gives you 10:1 I will have to cc the block first to see what I got just trying to get a good idea what I should shoot for I don't want to buy a set of alum heads and cant use them thanks
04-23-2016, 05:49 PM | #6 |
my calcs seem to indicate that with a 74cc chamber you might be very close to 9.1:1. Someone else can correct me Jim |
04-23-2016, 09:20 PM | #7 |
just going buy what ross is saying on there web site
04-23-2016, 10:26 PM | #8 |
Last year we built a 294ci engine with L-100 cam, we used edelbrock 74cc heads Milled for .045" piston clearance. This gave a Cr of 8.7. The L-100 bleeds of some of the pressure as the dynamic CR is around 7.5. Using a SBC dist set for 16 degs mechinical adv and 8 degs vac weve been running 87 oct gas with no problem. Check the AF as well, cruise should be around 15 and power 12.5. It;s in a 38 PU with Toyota 5 speed. Nice ride.
04-24-2016, 08:26 AM | #9 |
Thanks Ron I will have to cc my block and go from there to see what heads I should buy
04-24-2016, 11:36 AM | #10 |
Is the block relieved? That'll make a difference
04-24-2016, 12:01 PM | #11 |
No I'm going to get it done
04-24-2016, 01:24 PM | #12 |
O'Ron touched on an important point. It depends on what your cam timing numbers are. With a stock cam and low grade(regular 87 octane) about 8 to 1 is in the ball park.
04-24-2016, 01:39 PM | #13 |
425 camshaft is going in it
