06-14-2018, 05:25 PM | #1 |
'28-'29 open car dash reinforcement bar.
Was it riveted to the cowl post? Is there an alternative means of attaching it? Not doing an original restoration, just piecing together an old roadster pickup. Thanks,
Bob |
06-14-2018, 06:10 PM | #2 |
Re: '28-'29 open car dash reinforcement bar.
I never have heard of a dash reinforcement bar - pictures? Are you referring to the piece that goes above the gas tank? It is riveted to the cowl posts.
Rusty Nelson |
06-14-2018, 08:21 PM | #3 | |
Bob |
06-14-2018, 08:53 PM | #4 |
Bob,
I have a 29 phaeton and 28 roadster. Luckily both vehicles have a good "dash reinforcement bar" on them. I took a couple pictures of the ends of the roadster. I think you would need to get some countersunk head rivets to do it right. You can make a countersunk head rivet from a regular rivet with a drill and a file. I have done a lot of riveting and riveting the 2 rivets on each end don't seem very hard to do. The inside of the rivet is waffled. What I do is bolt everything together first and then remove one machine screw and replace it with a rivet. You need 2 people to do it. Use a decent buck on the outside. It looks like the rivets are 3/16" which can be set cold. It is possible they are 1/4", even though I don't think they are. I have found 1/4" rivets need heat - cherry red before setting them. A cheap air hammer will work, but a 3X or 4X rivet gun works better. Good luck. Rusty Nelson |
06-14-2018, 10:25 PM | #5 |
Bob |
