04-04-2020, 08:58 AM | #1 |
6 Volt to 12 Volt for Headlights only?
With these new inexpensive converters taking 6 volts to 12, has anyone successfully used one to convert only the headlights, and leaving the rest of the system at 6 volts? If yes, high and low beam?
04-04-2020, 09:23 AM | #2 |
Re: 6 Volt to 12 Volt for Headlights only?
My partner and I have been working on an all-purpose 6 to 12 volt converter box and have found that to make one that will handle much over 1 amp is not realistic.
04-04-2020, 10:37 AM | #3 |
Then there is the alternative of converting to 6 volt LED headlights.
Check this thread out.-------- https://www.fordbarn.com/forum/showthread.php?t=269053
04-04-2020, 11:31 PM | #4 |
if you run dual voltage your asking for trouble either run 6v or 12v these days you can buy reliable 6 volt gear and leds will generaly run between 6/36v and in the long term are a better buy
04-05-2020, 01:07 AM | #5 |
Any converter will have losses even the most efficient ones.
And there are 6v H4 bulbs and 7" inserts for them at fair prices...probably a lot less then 2 converters handling 10A+ will cost. |
04-05-2020, 11:46 AM | #6 |
04-05-2020, 10:02 PM | #7 |
I have a few 6v to 12v converters, and vice versa.
I have had mixed experience with them. Select about double the current rating you need, say a 10A output unit for a 6v heater. Last edited by fortyonerag; 04-07-2020 at 03:22 AM. |
