08-22-2013, 02:14 PM | #1 |
macs 600 oil on label 1 1/2 inches below fill plug
changing oil in trans and differential. do I do as directed on label
on oil container? they say to fill below fill plug. fredski |
08-22-2013, 02:21 PM | #2 |
Re: macs 600 oil on label 1 1/2 inches below fill plug
Yup!
08-22-2013, 02:31 PM | #3 |
08-22-2013, 02:45 PM | #4 |
The fill holes determine the fill level.
Bob |
08-22-2013, 03:27 PM | #5 |
Yep, just below the fill plug so your finger gets gets wet when stuck in to the first knuckle is fine. If you happen to end up filling it to over-flowing, won't hurt anything either. The oil expands quite a bit as it warms. These old cars are pretty forgiving.
08-22-2013, 05:48 PM | #6 |
08-22-2013, 07:04 PM | #7 |
am I correct in thinking adding rear diff oil below 1 1/2 inches of fill
hole ,will keep oil out of rear drum area if seals are not new. fredski |
08-23-2013, 01:48 AM | #8 |
rather have the oil at the fill hole. No guessing involved. Bob
08-23-2013, 04:10 AM | #9 |
NO, turns and rotational forces will cause it to leak even almost to empty.
