Old 07-17-2019, 06:27 PM   #1
emf
emf's Avatar
Default help with Mallory Unilite Distributor
I just purchased a Mallory Unilite and discovered it is 12 volt only. Not wanting to convert to 12 volts, I went to Holley's web site and discovered I can buy new points, condenser, and rotors for this unit. The only issue is that the unilite setup does not have a point cam on the shaft. Can I add a cam? where do I get one? Holley does not seem to offer one...
Frank
emf is offline   Reply With Quote
Old 07-18-2019, 05:46 AM   #2
updraught
updraught's Avatar
Default Re: help with Mallory Unilite Distributor
Don't know anything about them. Does it say 12 volts?
https://www.jalopyjournal.com/forum/.../#post-2222729
updraught is offline   Reply With Quote
Old 07-18-2019, 06:54 AM   #3
emf
emf's Avatar
It doesn't. Everything I've read indicates 12 volt supply is required.
Old 07-18-2019, 10:25 AM   #4
katy
katy's Avatar
You could get a 6V to 12V converter.
Don't go away mad, just go away.
Old 07-18-2019, 11:30 AM   #5
Jim Brierley
I would try and use points and condenser. I currently have a unilite and it starts fine but won't run under full throttle. I know of others that have had trouble with unilite.
Jim Brierley is offline   Reply With Quote
Old 07-18-2019, 11:54 AM   #6
emf
emf's Avatar
I just got off the phone with Mallory. This distributor cannot be converted to points, at least that's what tech support says. Any one need a Unilite???
Old 07-18-2019, 01:24 PM   #7
Dodge
I wonder if it could be converted to pertronix, they have 6 volt units.
Dodge is offline   Reply With Quote
Old 07-18-2019, 01:43 PM   #8
emf
emf's Avatar
That may be worth a shot....
Thread Tools
Display Modes
