Old 07-05-2019, 07:59 AM   #1
cederholm
cederholm's Avatar
Default clutch - embarrassing question.
So, I took this non-running flathead/transmission apart over a decade ago, and recently had her machined and outfitted with new parts. Now come the day when I mate the motor to the trans, fresh VanPelt clutch in hand. ...and I cant remember which way the clutch disk goes on. "spring side" towards the transmission or towards the motor. And by "spring side" I mean the side with the protruding spring plate.
Thanks!
Carl
PS - please don't tell my gear-head friends at the bar that I asked.
cederholm is offline   Reply With Quote
Old 07-05-2019, 08:07 AM   #2
oldskool
oldskool's Avatar
Default Re: clutch - embarrassing question.
springs face the trans
oldskool is offline   Reply With Quote
Old 07-05-2019, 08:13 AM   #3
cederholm
cederholm's Avatar
Thank you!!!
Old 07-05-2019, 08:31 AM   #4
Mart
Mart's Avatar
Some clutch plates are marked "Flywheel side" you might look for that.
Mart.
Old 07-05-2019, 08:32 AM   #5
RKS.PA
RKS.PA's Avatar
Don't be embarrassed! I had to refer to the clutch section of the "Green Bible" to get mine together right. Not something I do everyday!!
RKS.PA is offline   Reply With Quote
Old 07-05-2019, 08:38 AM   #6
deuce_roadster
deuce_roadster's Avatar
Most of us learned how the disk goes by pulling the motor and turning it around. Now I always hold the disk up to the flywheel with my dummy shaft and make sure I can spin it with no interference with the flywheel bolts.
Old 07-05-2019, 09:00 AM   #7
msstring
Thanks for asking because I would have been searching for the same answer soon. But, on a similar note what do you all use for alignment to get the clutch plate centered on the flywheel?
Sent from my LM-G710VM using Tapatalk
msstring is offline   Reply With Quote
Old 07-05-2019, 09:30 AM   #8
RKS.PA
RKS.PA's Avatar
Get yourself that little plastic alignment tool....it's a piece of cake!!
Old 07-05-2019, 10:07 AM   #9
cederholm
cederholm's Avatar
I bought a clutch kit from Mac VanPelt and that tool is included - very helpful.
Thanks again all, I'm old enough to know it's better to ask early and save myself a world of headache.
Old 07-05-2019, 10:44 AM   #10
drolston
drolston's Avatar
I thought everybody had an old transmission front shaft in their junk box for installing clutches!
Old 07-05-2019, 10:49 AM   #11
cederholm
cederholm's Avatar
!!!FOLLOW UP QUESTION!!!!
So here is my situation I have a big buddy over here to help me install the transmission with promises of beer and loose women (though I can only provide the beer) but I'm missing my throwout bearing return spring. Can I install that later through the inspection plate on top? ...and do I need to "proper" spring or will a hardware substitute work?
Thanks again!
Old 07-05-2019, 10:49 AM   #12
philipswanson
That works better.
philipswanson is offline   Reply With Quote
Old 07-05-2019, 11:01 AM   #13
Kube
Kube's Avatar
Thanks again!
I'd suggest you get the dedicated spring. I believe it will be impossible to install once the transmission is in...
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Kube is online now   Reply With Quote
Old 07-05-2019, 04:43 PM   #14
msstring
Originally Posted by philipswanson View Post
That works better.
I wish I did. This has been an ongoing hobby project for many years. Not something I do often enough to accumulate that assortment tools like a stub shaft. I'm guessing not just any shaft fits a 48 F3...
Old 07-06-2019, 07:58 AM   #15
chap52
chap52's Avatar
Put the correct first. Can't imagine being able to do it later. When I replaced the clutch in my 52 F-1 I had my new clutch and PP ready to go and after a closer look found that the TO Hub was worn. Had Mac van Pelt send me a new hub and spring. Then put it all together. Easier than doing it all over again in a month... Chap
chap52 is offline   Reply With Quote
Old 07-06-2019, 08:06 AM   #16
cederholm
cederholm's Avatar
Good advice all. Thanks!
Thread Tools
Display Modes
