Old 05-24-2019, 10:02 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Finish for wheel cylinders
I am looking for a finish for wheel cylinders that brake fluid won't remove. I was thinking powder coating but I not sure if it is impervious to brake fluid or not. I am open to ideas. Perhaps Parkerizing or black oxide?
TIA
1930 Tudor
Early 1930 AA
Old 05-24-2019, 10:12 PM   #2
3twinridges
Default Re: Finish for wheel cylinders
TIA
Eastwood makes a nice brake parts paint that has held up well for me
JB
3twinridges is offline   Reply With Quote
Old 05-24-2019, 11:44 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
I believe that powder coating would work - but ask a few vendors.
Old 05-25-2019, 01:24 AM   #4
expavr
expavr's Avatar
I had backing plates powder coated and the finish has so far resisted DOT 3. On a cautionary note the powder coating material flowed into a few of the bolt holes reducing them in size which had to be drilled out to accept the bolts. Could be a problem with the wheel cylinders.
expavr is offline   Reply With Quote
Old 05-25-2019, 06:15 AM   #5
Mac VP
Mac VP's Avatar
Powder coasters have a variety of special elastic plugs available for blocking holes in parts that you don’t want the coating going into during the baking process. Obviously, the bolt holes and the cylinder bores would need to be plugged on a wheel cylinder. Naturally the pistons, cups, and boots would be removed first.
VANPELT SALES LLC
Cincinnati, Ohio
800-299-7496 (in USA)
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 05-25-2019, 11:58 AM   #6
Flathead Fever
Flathead Fever's Avatar
Years ago they powder coated all the rack heads and exposed pieces on the old-style in-ground Weaver hoists at work. We spilled every automotive chemical you can think on that powder paint and only one thing phased it, Carburetor cleaner. It took the powder paint off just like paint remover removes paint.
Old 05-25-2019, 12:47 PM   #7
Chris Haynes
Thanks for the information.
1930 Tudor
Early 1930 AA
Old 05-25-2019, 03:20 PM   #8
Pete
Pete's Avatar
TIA
Either Parkerizing or black oxide will work fine.
Old 05-25-2019, 07:09 PM   #9
Chris Haynes
I agree. However most of the shops around here that did it are long gone due to haz mat laws. Those that are left do bulk work and charge bulk prices.
1930 Tudor
Early 1930 AA
Old 05-26-2019, 08:50 AM   #10
john in illinois
john in illinois's Avatar
I use this product on screws and nuts. It would work on wheel cyls too. I usually bead blast the part and it looks like parkerizing. comes out Matt black.
Part has to be clean. Wipe it on.
https://www.brownells.com/gunsmith-t...-prod1072.aspx
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 05-27-2019, 04:08 AM   #11
aussie merc
aussie merc's Avatar
never even gave gun blue a thought but why not will keep it in mind
aussie merc is offline   Reply With Quote
Old 05-27-2019, 09:54 AM   #12
philipswanson
There is a guy tat advertises in Hemmings that presses in a brass sleeve into wheel cylinders.
philipswanson is offline   Reply With Quote
