04-25-2017, 01:32 PM | #1 |
machining 1934 motor block for main's
i need to know what the engineering diameter and tolerance is for the main's on a 1934 block.is there someone here that i can talk too about this?
04-25-2017, 01:41 PM | #2 |
Re: machining 1934 motor block for main's
Pouring Babbitt?
04-25-2017, 01:54 PM | #3 |
If you are doing the job yourself mike the journals and allow for about .002 oil clearance.
If a shop is doing the job they should have all that is needed to do it. The main bearings are poured babbitt. |
04-25-2017, 03:49 PM | #4 |
Here are nos factory bearing caps-- ready to bore for crankshaft size
It is hard to fit inserts properly because of the wide deep oil grooves not having good support |
04-25-2017, 04:40 PM | #5 |
Lawrie |
