07-01-2019, 10:00 PM | #1 |
Engine Splash Pan Installation Documentation?
My new-to-me Model A didn't come with engine splash pans and I am looking to correct that to help with cooling.
So far I haven't been able to find any documentation on exactly how they're installed. I believe I felt the holes on the outer side of the frame, but am unsure where exactly the two notches on what I believe to be the engine side are connected to. Any resources I could be pointed to would help. |
07-01-2019, 10:06 PM | #2 |
Re: Engine Splash Pan Installation Documentation?
There are three holes on the frame,the two holes on the other side are held in place with the sump bolts.
07-01-2019, 10:19 PM | #3 |
This thread might be moderately helpful.
https://www.fordbarn.com/forum/showthread.php?t=111606 |
07-04-2019, 01:08 PM | #4 | |
I appreciate the link, though that thread is more about the benefits of having them installed versus the actual installation.
Feels like I'd have to seriously bend the entire splash pan as the sump bolts are about an inch higher than the bottom of the frame. And, of course, it looks like not all of the holes line up. *sigh* Why is nothing easy? |
07-04-2019, 02:02 PM | #5 |
Welcome to the wonderful world of repro parts
07-04-2019, 04:05 PM | #6 | |
I tap the holes 5/16-18 in the frame to facilitate installation. Last edited by Ruth; 07-04-2019 at 04:11 PM. |
07-04-2019, 04:12 PM | #7 |
And if you have a 1928 there are two (one on each side) that bolt to the front frame crossover..
07-05-2019, 02:33 PM | #8 |
I just reinstalled mine and like was said there are three holes on the frame (you will need another pair of hands) and two slots for the oil pan bolts. The only thing I will do the next time is maybe put a rubber spacer under the pan bolts to help with vibration as apparently the pans crack due to it. At least that is what I have heard and the really thin metal makes me believe it.
Mike
07-05-2019, 03:19 PM | #9 |
I installed some 'washers' to spread out the contact area of the bolts to the sheet metal.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 07-05-2019 at 03:28 PM. |
07-07-2019, 08:01 AM | #10 |
I like Ruth's idea of tapping the frame. Otherwise you need about three hands to install.
Marty |
07-07-2019, 06:40 PM | #11 |
They are easy to put on by yourself. Just take the front fenders off first. .........lol
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
07-07-2019, 06:42 PM | #12 | |
John |
