01-01-2013, 10:38 AM | #1 |
Amount OF TIME TO BUILD YOUR CAR
It took me 11 years to build the 40 coupe in my avatar only after i retired could i finish it....gump
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
01-01-2013, 10:56 AM | #2 |
Re: Amount OF TIME TO BUILD YOUR CAR
My restorations take between 12 - 16 months. These are all ground up projects, very high point (authentic) restorations. That 12 - 16 months is not "full time" but equates to (approximately) between 900 - 1400 hours.
11-05-2014, 05:11 PM | #3 |
I'm curious as to the starting condition of a car that you can restore in your time frame. Maybe a better question is how do you evaluate a car to determine if it's a candidate for a high point restoration. And would the 1400 hours reflect work that's done outside your shop, if any? You have done some beautiful cars by the way.
01-01-2013, 11:21 AM | #4 |
Since my builds are not "restorations" but drivers that represent a theme or time period, and the fact that I'm not retired, definitely has its pluses and minuses on build times. My 40 coupe took about 2.5 years part time to "rebuild" not restore to a late 50s theme, my avatar took 7 years (time and money were definitely issues along with my quest to make it as authentic an early 50s hot rod that I could make it), my present 40 p-up has so far taken 2+ and it will be a more early 60s theme. But, retirement is getting closer and it will be done sooner rather than later I expect because of that fact. I also get side tracked due to family, other interests, and other issues like just not wanting to do anything at that time - it is a hobby for me and I don't want that to change and make it "my day job". I have a 32 5-window in the wings that needs tons of work - we'll see how long that takes me!
What I do try and do is do a little something (if not more) in the garage whenever possible - that really helps keep me focused - even if it's not on the present project . |
01-01-2013, 11:49 AM | #5 |
Hey Tom, I completely understand (and relate well to) your post in regard to other commitments, etc. taking a toll on the time frame required to complete a car.
When I was younger it seemed I could never get the requisite amount of cash AND time to coincide. It seemed I always had one or the other but never both. Being retired does make it a bit easier to concentrate on my hobby. Still, like you, there remains commitments beyond the shop. I suspect that will never change, nor would I desire it to. Currently I am restoring three cars simultaneously. One is near the finish mark, another is down to the bare bones and lastly, one has just been pulled in and has not yet been disassembled. I have come to realize I thrive best in overwhelming" situations. Hey, I bring it upon myself That reminds me, I'd better get out there and get something done.
01-01-2013, 12:07 PM | #6 |
Seabright Hot Rods |
01-01-2013, 12:05 PM | #7 |
I have about 6 years into the F-1, the longest it has taken me to restore a truck. Would love to have done by August for the Woodward Dream Cruise. Ken
01-01-2013, 12:11 PM | #8 |
Ten years on my '39 Standard coupe.
80% finished... 80% left to go. The '37 Tudor is done and fun.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
01-01-2013, 05:37 PM | #9 |
01-01-2013, 12:37 PM | #10 |
Well, for my two cents there are different levels of restoration. The last original unrestored barn find '40 car I found and made into an original, dependable, unrestored great driver took me two months. No paint work, seats redone, fuel and brake system completely redone, fluids changed, engine unstuck, valve train pieces replaced, full tune up, two pieces of glass replaced, tie rod ends, king pins, wipers redone, tires, tubes, and powder coat the rims. I worked about 4 days a week and about 5 hours a day. I'm very familiar with the '40 model Ford products and this makes it much easier for me.
01-01-2013, 01:11 PM | #11 |
Are you guys familiar with the Lynn Yearwood theory of Automobile Restoration? According to Lynn, any Car can be built in 2 years. The theary is you go to the garage one time every day even if you do nothing but take out or put in 2 bolts. 2 bolts a day equals 14 a week, 62 a month or 728 a year. That is 1456 bolts out and back in in 2 years ....hence, The Lynn Yearwood Theory of auto restoration.
Never made it work myself. 6 years for mine. John L
Just slightly abrasive |
01-02-2013, 11:51 AM | #12 | |
01-01-2013, 01:14 PM | #13 |
This is a real advantage, not one most of us have. I do have 2 1950 F1s, but the rest are all different. If you drive your project, it is truly never finished. Bruce Works good Lasts long time |
01-01-2013, 02:31 PM | #14 |
01-01-2013, 01:19 PM | #15 |
Kube,3 cars at the same time,Wow.I find working on more than one car at a time diminishes the sense of accomplishment,not to mention the mixing of parts.But more power to you if you can pull it off,and it seems you con.Phil
01-01-2013, 03:07 PM | #16 | |
That is no doubt the main reason that "forces" me to restore the cars to the level I insist of myself. So, it is second nature for me to keep exacting inventory of each vehicles parts, assemblies, etc. separate from one another. My sense of accomplishment is only diminished by the fact I am never 100% satisfied with my finished works. I always find areas I feel I could have done better. I am self motivated enough so that all three will be done in a relative decent time frame. In fact, doing two or more at a time kind of helps me in that if I get frustarted on one vehicle, I can simply move to a different project. Today? Installed one rear fender and the front seat on one and rebuilt and refinished the generator for another. Don't get me wrong, there are days that I simply get over whelmed and little (nothing?) gets accomplished. I won't claim my way of enjoying this hobby is the best way. In fact, I would think the opposite to be true for most. Still, this is precisely the way I get the most reward from it.
01-01-2013, 03:41 PM | #17 |
i never really put a time frame on my restorations, maybe i should. although i do have certain goals, as long as i make progress and the work that i did get done, was done correctly i am happy with that. although i don't work on them as much as i should, i do have (like most of you) my family, my work, and a house to maintain. its easy to tear a car apart, but finishing it is the challange. look how many cars that you know about or even bought because that person lost interest or even didn't have the amount of time or skill that is required to finish a car, so they shoved it in a corner or pushed it outside. Jim
01-01-2013, 04:48 PM | #18 |
I have about 2 years into my 46 tudor sedan. It was in good shape when I bought it but I wanted to make it my own. When I bought the 46 it was dark blue with blue garnish moldings and blue window tint blue rims. All that blue was giving me the blue's. I wanted to change the color to burgundy body and rims. Metallic gray garnish molding and dash steering column. Removed all of the window tint which was a pain in the behind. I also removed the complete front end and pulled the motor and went through it. POR15ed the frame and front axle. Painted the car and put everything back together. The last thing I did to it was bought one of them gas tank door moldings for it and installed it to which I don't like the looks of it and will be removing it and probably resell it. Now I just drive it when ever I can.
The Lord is the light--allow Him to guide you. |
01-01-2013, 05:38 PM | #19 |
Two and a half years to restore it to a 978 point car , 28 years to get around to it!
happy new year guys |
01-04-2013, 11:49 AM | #20 |
My first ground up restoration was a 28 Buick Town Brougham. I was practicing law the whole time, and trying to help the wife raise 3 kids. It took me 12 years to finish the restoration. The second was a Canadian built 34 that I restored, but did not remove the body from the frame. l0 years as I was still working full time. Next is the 35 PU in my Avatar. Gathered parts to build it from all steel parts. I believe it stretched out over about 18 years.
