11-06-2010, 05:33 PM | #1 |
50 lb Oil sending unit
City:
Placerville
State:
Calif
Need Oil Pressure sending unit, early stock working 50 lb unit with the 50 lb mark on base. It now has a 80 lb sending unit with a 50 lb pump and the reading on gauge is off.
Thanks Mike/ [email protected] Last edited by 40mike; 11-06-2010 at 08:07 PM. Reason: Title edit |
11-07-2010, 08:26 AM | #2 |
Re: 50 lb Oil sending unit
Mike: Prior to 1942 the car oil sending units had no markings on the base, all were 50#. Only when they went to the 80# system did Ford start marking the bases either 50# or 80#. The ones with the 50# markings were designed as replacement units for the pre-42 cars. I have a couple of very good used 50# (base unmarked) units. $30.00 plus shipping cost.
[email protected] |
11-07-2010, 08:42 PM | #3 |
Here are two old Fordbarn posts that I had copied into my files for future reference. They might interest you regarding finding a 50# oil pressure sending unit:
1. The sending units were manufactured by King Sealy and have a KS logo stamped on the top. They made 50# units for Willy's, Kaiser, Packard, and others as well. Let you in on a secret, essentially the 50# pressure units were the same. The only difference from Ford was the thread that fits into the block. Ford used a larger thread. I have found the Willy's (PN 647571) and using an off the shelf adapter have been able to fit the sender into the Ford FH V-8 without affecting performance. Look for these on e-bay or at a Jeep parts house or auto parts store. 2. Kaiser Willy's Has the 50# sending units, But like mentioned by others they had smaller thread so a adapter is needed for Ford application. The Part is made in the U.S.A. by Crown the part # is 3212004. You can contact them at: [email protected]
11-08-2010, 05:18 PM | #4 |
