11-20-2021, 04:26 AM | #1 |
Flying Flathead
A friend sent this and don't know if it has been shared here.I could only copy part of the text.Pretty cool.Maybe DD can elaborate!!
FW: Ford-men legends - Ford’s Flying Wing The Flying Flathead Prior to the Flying Wing design of the B-2 Stealth Bomber or the WWII German Horten, Ford built a tail-less Flying Wing aircraft powered by a Flathead. When the 75hp Ford Flathead V8 first came out in 1932, a special high performance batch of all-aluminum Flatheads were built that made 115hp. It was this special version that powered Ford’s new aircraft called the Ford Flivver 15P. |
11-20-2021, 04:42 AM | #2 |
Re: Flying Flathead
One reason it never flew was they couldn’t find a pilot stupid enough to climb into the cockpit. Just one reason.
Alan |
11-20-2021, 09:36 AM | #3 | |
Re: Flying Flathead
I would sure like one of those aluminum flatheads, though. |
11-20-2021, 10:07 AM | #4 |
Re: Flying Flathead
Denny I thought the same. Light weight & 115 h p in a Model A 2 dr sedan....YES !
As for the flying machine, I,ll stick with The Tri Motor. Lots of rides as a youngster & flew right seat at 9 yrs old. Hearald let me take the yoke & he stayed on the rudder pedals. What a blessing !!!! |
11-20-2021, 10:35 AM | #5 |
Re: Flying Flathead
Ah, Island Airlines' Tri-Motors to and from Port Clinton and Put-in-Bay; low, slow, and a barrel of fun never to be forgotten.
11-20-2021, 10:52 AM | #6 |
Re: Flying Flathead
All in all, the best $75 I ever spent. I think I'll check and see if they are coming back this winter! |
11-20-2021, 11:01 AM | #7 |
Re: Flying Flathead
A ride in a tri-Motor should be on everyone's bucket list. Was able to do it about 4 years ago and it was the thrill of a lifetime. As tubman says "the best $75 I ever spent". Actually at the time I would have paid twice that amount just to get the ride.
11-20-2021, 02:32 PM | #8 |
Re: Flying Flathead
While the idea of the Ford flying wing was no doubt scary I wonder where aviation would have been had the idea progressed. Maybe advancing designs a few decades earlier than what actually finally developed many decades latter. works.
It would be nice to find out lots more about the aluminum flatheads used for the project. The Granateli brothers also know as GranCor once advertised aluminum Ford flatheads for sale no doubt surplus from some Ford project. Maybe from the flying wing era. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 11-20-2021 at 02:37 PM. |
11-20-2021, 02:45 PM | #9 |
Re: Flying Flathead
https://oldmachinepress.com/2016/04/...onal-aircraft/
Directly aft of the firewall behind the pilot and passenger was the Ford flathead V-8 engine. Although engine specifics have not been found, the engine most likely had a 3.0625 in (77.8 mm) bore, a 3.75 in (95.3 mm) stroke, and displaced 221 cu in (3.62 L). The engine is noted as being virtually standard so that parts would be available from most Ford auto repair shops. Unique to the aircraft engine was its all-aluminum construction and that it produced 115 hp (86 kW) at 4,000 rpm.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-20-2021 at 03:24 PM. |
11-20-2021, 03:00 PM | #10 |
Re: Flying Flathead
https://oldmachinepress.com/2016/04/10/ford-15p-personal-aircraft/
Very little information regarding the Ford 15P remains. The aircraft’s approximate specifications are a wingspan of 34 ft (10.4 m), a length of 14 ft (4.27 m), and a gross weight of 1,600 lb (726 kg). The 15P had an estimated top speed of 120 mph (193 km/h) and a maximum range of 500 miles (805 km).
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-20-2021 at 03:33 PM. |
11-20-2021, 04:39 PM | #11 | |
Re: Flying Flathead
Most-assuredly, if you ever get the chance to ride in a Tri-Motor Ford, GO! I rode on my first one at Oshkosh in 1981...yup, the year of the controllers' strike while Oshkosh was going-on. I remember back then, it cost $15 to go around the patch in that noisy old rattling Ford. More to the subject at hand, the Ford 15P. I remember talking about this airplane on this forum some time in the distant past. It surely was different, to say the least. Some beautiful metal-pounding for sure by talented artisans, with such talents being very rare today. A couple of folks here have commented that there was no fin, no rudder and no (vertical) stabilizer. Well guys, the old YB-49, as well as today's B-2 and now the new B-21 are all what we commonly refer to as a "flying wing", and their stable flight, especially the current models, is well under control in the 'YAW' axis via "drag rudders", mounted on the outboard, rear of each wing, as is stated in the accompanying article on the "P15"....click the link BELOW. https://oldmachinepress.com/2016/04/...onal-aircraft/ A couple of you even suggested that the "P15" never even flew, which is incorrect. The airplane made several flights sometime after early 1936, all flown by Ford head pilot Harry Russell. Ever since the early '60s, I have heard tell of 10 "special" aluminum Ford flathead blocks that were produced for aircraft applications. This "P15" apparently got one of those special critters. The one detailed picture of the engine shows some interesting features for us flathead aficionados to ponder. Click the link BELOW for a LARGER, more-detailed picture. https://oldmachinepress.files.wordpr...15p-engine.jpg The heads appear to be the pump-in-head type currently in use on Ford cars at the time (1936), mounted backwards. The fuel pump location should define the "rear" of the engine. In addition, drive duties should always be undertaken by the flywheel end of the crankshaft. Furthermore, the angle of the fan belt suggests that two later style water pumps were in use to circulate water. One other note is that the propeller is pitched such that it must turn in the NON-STANDARD, reverse direction of clock-wise as seen while facing the aircraft from the front. The normal flathead crankshaft rotation would be counter-clockwise as seen while facing the aircraft. But alas, MOST propellers can't stand to be turned at the crankshaft speeds that the flathead was capable of turning. Therefore, it is most-likely that there was a geared-reduction box in the system, therefore necessitating the propeller to be of the reverse-pitch variety. I would be interested in seeing any additional pictures that anyone may have of this aircraft, or additional history on it's eventual demise. It should be noted here that this airplane had nothing to do with an aircraft known as "Ford's Flying Flivver". That was an aircraft that Ford was developing ten years earlier to "put a Ford airplane within every man's reach". It crashed off the Florida coast as a result of a toothpick being placed in a fuel cap vent hole by it's Ford pilot Harry Brooks, and forgotten. DD Brooks & The Flivver . |
11-20-2021, 04:42 PM | #12 |
Re: Flying Flathead
tubman,
We may have been passengers on the same flight. |
11-20-2021, 05:59 PM | #13 |
Re: Flying Flathead
11-20-2021, 06:33 PM | #14 |
Re: Flying Flathead
I similarly had a great time getting a ride in a Tri-motor several years ago out of San Carlos airport south of San Francisco, exceeded only by a ride in the B-17 "Aluminum Overcast" out of the old Mather AFB near Sacramento the next year. now THAT was definitely the best $400 I've ever spent!
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
11-20-2021, 06:59 PM | #15 | |
Re: Flying Flathead
11-20-2021, 07:29 PM | #16 |
Re: Flying Flathead
OOPSIE! |
11-21-2021, 12:41 PM | #17 |
Re: Flying Flathead
Hotrod Mag had a write up on this engine back in the 60's. Had a picture on the cover.
Yes, I was a member of EAA and had a ride in their Tri motor. Gramps |
11-21-2021, 04:44 PM | #18 |
Re: Flying Flathead
I was lucky enough to fly on the Collins Foundation's B-17. It crashed 11 days later at Bradley. It was an amazing ride but I'd have to think a bit before I'd go up in another vintage aircraft. The Tri-motor is cool. It would be hard to say no to a ride.
11-21-2021, 11:07 PM | #19 |
Re: Flying Flathead
Is that belly landing photo the Bradley crash? My dad had a friend who was a ball turret gunner on a B17. You just had to respect that guy for his part.
11-21-2021, 11:33 PM | #20 |
Re: Flying Flathead
Coop you go to Oshkosh? My uncle built a plane in his basement and the corvair motor started spitting oil after a few flights and he had to make a dip wing field landing. He survived. He keeps telling me to go to Oshkosh, he goes every yr. Nasa has booths there. Big event. Sounds fun!
