11-18-2018, 11:22 AM | #1 |
Radio Fuse
What size fuse should be used on 1949 ford radio
Sent from my SM-T550 using Tapatalk |
11-18-2018, 05:37 PM | #2 |
Re: Radio Fuse
Valve radios actually draw a fair amount of current, @ 4 - 8 amps, but that being said a 10A fuse should be about right for your application.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
11-18-2018, 06:10 PM | #3 |
Re: Radio Fuse
Thanks I thought a 10 amp should be adequate yet provide protection
Sent from my iPhone using Tapatalk |
11-18-2018, 06:23 PM | #4 |
Re: Radio Fuse
I seem to remember that the owners manual for my '51 calls out a 14 AMP fuse. If nobody comes up with a definitive answer, I'll double check it tomorrow.
11-18-2018, 07:22 PM | #5 | |
Re: Radio Fuse
But for the wire size 14 amp is what is called for.
11-19-2018, 10:50 AM | #6 |
Re: Radio Fuse
http://oldcarmanualproject.com/manua...rs0019_jpg.htm
https://www.youtube.com/user/roosty6/videos |
11-19-2018, 11:49 AM | #7 |
Re: Radio Fuse
Sfe-14
11-19-2018, 11:50 AM | #8 |
Re: Radio Fuse
You can go lower that the amp rating for the wire with no problem. A person shouldn't exceed the amp rating of the wire in any case. A 16 gauge wire with a short run would only require a 10-amp rated fuse. A 14 gauge wire of the same length would require a 15 amp fuse. I'm not sure what the wire gauge is on the radio.
11-19-2018, 07:10 PM | #9 |
Re: Radio Fuse
The SFE-14 is a specific length to fit in the radio's fuse holder. One cannot change amperage as the length will be different.
11-20-2018, 10:39 AM | #10 |
Re: Radio Fuse
SFE fuses are just a fast blow type of glass body fuse of specific lengths. They are still manufactured in multiple amperage ratings for different size conductor wires. Here is a link to different ratings.
https://www.fusesunlimited.com/products/sfefuse There are other fuses of the same or similar length that could be substituted but there is no good point to that. Some fuse holders will accommodate different lengths since there is just a spring in there. A longer one will bottom out but a shorter one may still fit. Last edited by rotorwrench; 11-20-2018 at 11:02 AM. |
11-20-2018, 11:03 AM | #11 |
Re: Radio Fuse
NAPA has them. Most places do not have them.
