Old 03-10-2018, 11:29 AM   #1
toms32
Default model B head
I have an opportunity to purchase a model B head for my model A engine. Will this help in performance ? Are their any other things that I have to do to install the model B head ? Any guidance would be appreciated. Tom
toms32 is offline   Reply With Quote
Old 03-10-2018, 11:47 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: model B head
The head that looks like the a head wit B on it just bolts on--- look for cracks in the center
The model "B"head with the C on it you need the matching watwepump and head gasket to match
Old 03-10-2018, 11:49 AM   #3
Jim Brierley
The '32-'34 heads have a large 'C' cast on the top, and are a little higher compression than the A head, and a 3-bolt water pump rather than the 4-bolt on the A heads. If your head has a large B cast on top, it is a 'police Special' made by Ford for ... you guessed it, police cars. It would have even (slightly) higher compression ratio than the C head. Both will increase the power of your A, and have no ill effects on the engine. I'm not sure but believe both had less than 5:1 compression, not very much by today's standard.
Jim Brierley is offline   Reply With Quote
Old 03-10-2018, 11:51 AM   #4
Bob C
If you asking about the 1932-34 head I don't see much gain. The compression ratio
of the A head is 4.2 and the B head is 4.6 plus the 1932 water pump can be expensive.
Bob
Old 03-10-2018, 12:44 PM   #5
Benson
Benson's Avatar
head with Large C is called "B head" is 4.6 with 3 bolt water pump
Head with large B is 5.2 with 4 bolt water pump called Police head was originally sold ONLY to Police departments starting sometime in 1930 or 31 then later sold to public.
I have run a "head with the large B" 5.2 on several different A and B engines for total of 55,000 miles since 1962 no ill effects.
I went on the Mt Evans run with one of the Model A Clubs in 62 or 63. Starts in Denver at 5200 feet and goes to top of Mt Evans at 14,260 feet.
We stopped at Idaho Springs for lunch and a couple of guys with shinny "fine point" cars were pointing out ALL the things that were "wrong" about my Sport Coupe in "fine point" detail ... one thing after another!
Finally after 10-15 minutes of this jabber one fellow listening to all of this, asked "How come his car outruns all the other cars?".
Bill Kenz who was listening to all of this said "That is because he has a Police Head on his car."
Mr. Fine point said "What is a Police Head??" Duh!
Benson is offline   Reply With Quote
Old 03-10-2018, 12:51 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
[QUOTE=Benson;1603313]head with Large C is called "B head" is 4.6 with 3 bolt water pump
????? Then would the head with the large B be called C head? Just curious?
Old 03-10-2018, 12:52 PM   #7
daren007
How does the water outlet line up with the radiator?
daren007 is offline   Reply With Quote
Old 03-10-2018, 01:14 PM   #8
Benson
Benson's Avatar
[QUOTE=Chuck Sea/Tac;1603314]
????? Then would the head with the large B be called “C” head? Just curious?
The head with the Large B was called a Police Head originally came on Model A engines.
"Head with Large C" is called a B head because it was installed on Model B engines..
This is why for 55 years I have been calling them
"THe head with the Large B" 5.2 AKA Police head
And the "head with the large C" 4.6 to eliminate confusion.
Old 03-10-2018, 01:50 PM   #9
Growley bear
The outlet aligns well; my Model A hose was an inch or so short so a longer hose is needed.
Growley bear is offline   Reply With Quote
Thread Tools
Display Modes
