Old 03-05-2018, 04:34 PM   #1
sphooch
sphooch's Avatar
Cool venturi removal tool
Hi Guys, need some help here. I'm trying to understand HOW THE VENTURI REMOVAL TOOL ACTUALLY WORKS. I HAVE THE CARBURETOR REBUILD BOOK BY Paul Moller WERE HE SHOWS HOW TO MAKE ONE BUT FAILS TO EXPLAIN HOW TO USE IT. I've searched this site with no success. any help will be greatly appreciated thanks THE HOOCH
sphooch is online now   Reply With Quote
Old 03-05-2018, 04:57 PM   #2
Jim/TX/GA
Jim/TX/GA's Avatar
Default Re: venturi removal tool
Look at this:
https://www.model-a.org/venturi_extraction.html
Jim Cannon
"Have a Model A day!"
  • Repair
  • Restore
  • Drive
  • Enjoy!
  • Join MAFCA
http://tinyurl.com/Join-MAFCA
Jim/TX/GA is offline   Reply With Quote
Old 03-06-2018, 12:15 PM   #3
Anteek29
Anteek29's Avatar
My Zenith has a very loose venturi...could this be the reason why I cannot get my A to idle properly? Should the venturi fit snugly in the body?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-06-2018, 12:31 PM   #4
BillCNC
BillCNC's Avatar
They can be made with a piece of all-thread, a couple of nuts, washers and a rubber plug.
Double nut the bottom> washer > rubber plug> washer > and the last nut.
Put the plug into the venturi, tighten the top nut until the rubber plug expands inside the venturi and tightens up gripping the venturi and simply pull it out. If it's stuck in real good, you will need to use a penetrating oil FIRST regardless of which method is used to remove the venturi.
The rubber plug method is really the only one to safely remove them without the fear of damaging it an any way, unless they simply fall out like one of my (3) Zeniths-1 did.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-06-2018, 02:51 PM   #5
johnbuckley
johnbuckley's Avatar
It should be a snug fit from an engineering and theoretical point of view ..... But a loose venturi is usually no problem ( unless it's loose even when upper and lower halves are bolted up together ) since the main gasket between the upper and lower bodies seals it. The Venturi has next to no effect on idling..... it's presence is to increase the airspeed as it passes across the openings of the main and cap jets ( which aren't deployed at idling) . You can even take Venturi out completely and the car will normally idle just the same.
Removal.... they can be an absolute B*****, , they can be seized into the U and L body castings. splitting when you separate the bodies . it's then you often find that someone has previously mangled them trying to effect removal, Try penetrating oil, puller, gentle tapping of central section of puller with hammer, heat and more tapping ditto , thermal shock ( in that order) .... and I had one today that someone had so severerly b*ggered in the throat of the lower body that I had to melt it out with an acteylene/propane torch.
johnbuckley is offline   Reply With Quote
Old 03-06-2018, 03:47 PM   #6
Joe K
Joe K's Avatar
I did the melt removal of my seized (and later mangled by me in attempt) with an acetylene torch - and found that the repop venturi fit loose - but as said, the gasket "centers" it and the two body halves "clamp" it in place.
Not my favorite carb - but works well as a spare below the seat.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-06-2018, 04:29 PM   #7
1crosscut
1crosscut's Avatar
Grab the shaft on your butterfly valve and see if there is movement where it passes through the side wall of the carburetor. If worn it can pull too much air in through there causing idle problems.
Dave
It'll feel better when it quits hurting.
1crosscut is offline   Reply With Quote
Old 03-06-2018, 08:34 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I had to torch a couple venturi out, but be sure to wear a full face shield, because that pot metal likes to splatter when heated.
Old 03-06-2018, 10:38 PM   #9
ursus
I am surprised that nobody has yet mentioned an old and effective trick for removing a stuck venturi!! Place the assembly in oven at 400 degrees Fahrenheit for 10 minutes. Remove assembly and place in paper bag and place this in the freezer for another 10 minutes. Remove the bag and tap softly on a piece of wood and the venturi will fall out. Works for me.
ursus is offline   Reply With Quote
Old 03-07-2018, 07:20 PM   #10
BillCNC
BillCNC's Avatar
I would think 400 would cause the paper bag to ignite and or melt the inside of your freezer.
YES, ... that kind of expansion and contraction would certainly do the trick without the use of penetrating oil.
Regards
Bill
Thread Tools
Display Modes
