Old 09-10-2015, 12:35 PM   #1
Peter Pucak
Default Starter Question
In trying to start my engine I ran into this situation: engine turned over but would start. Put the hand crank in to reset and check the timing but the engine would not turn. Removed the starter and saw no damage to the bendix or the ring gear. Put the hand crank in and the engine turned. Installed the starter and was able to turn the engine with the hand crank. Can anybody give me some ideas with this problem. Thanks Peter
Peter Pucak is offline   Reply With Quote
Old 09-10-2015, 01:20 PM   #2
Brentwood Bob
Default Re: Starter Question
clean the bendix helix and check the starter switch, and the auxilary fuse block, the fuse block is poorly made.
Bob
Brentwood Bob is offline   Reply With Quote
Old 09-10-2015, 01:30 PM   #3
Bruce Adams
Bruce Adams's Avatar
Fuse should have nothing to do with the starter as it is AFTER the starter electrically.
Is there a chance your car was in gear when it would not turn over by crank?
Sometimes I miss these things while involved in a repair.
Bruce Adams is offline   Reply With Quote
Old 09-10-2015, 01:39 PM   #4
burner31
burner31's Avatar
Ditto on being in gear, been there...done that.
Sometimes I forget to turn the gas on too.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-10-2015, 01:43 PM   #5
glenn in camino
glenn in camino's Avatar
Your bendix gear hung up on the flywheel ring gear.
glenn in camino is offline   Reply With Quote
Old 09-10-2015, 04:34 PM   #6
Brentwood Bob
Thanks, bruce. It would still be a good idea to check the fuse assembly when you disturb the starter switch. I eliminated mine.
Bob
Old 09-10-2015, 04:43 PM   #7
CWPASADENA
CWPASADENA's Avatar
When this happens, put the car in gear and rock it back and forth. This will usually un-stick the bendix.
If you drive an old Ford long enough this will happen. Just a very minor inconvenience. This problem may not occur again for years.
If it keeps happening on a regular bases, remove the starter and inspect the bendix and the flywheel ring gear.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-10-2015, 10:11 PM   #8
Peter Pucak
Thank You All for your comments. The car was not in gear. Peter
Thread Tools
Display Modes
