Old 09-09-2015, 09:39 PM   #1
1930artdeco
1930artdeco's Avatar
Default Inside u joint cover
Quick question folks. Does the inside u joint cover only go on one way? Or can it be rotated any whic way?
Mike
1930 TownSedan (Briggs)
Still learning after all these years....
Old 09-09-2015, 10:21 PM   #2
daveymc29
daveymc29's Avatar
Default Re: Inside u joint cover
The inside has a hole in it that I think should go right with the grease fitting on the outside piece, though it will fit either way. But perhaps someone with more knowledge than I will have another answer and differ in reasoning.
daveymc29 is offline   Reply With Quote
Old 09-09-2015, 10:32 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I always put the inside cover so the two holes are located at 9 and 3 o'clock.
Old 09-10-2015, 08:18 AM   #4
burner31
burner31's Avatar
When greasing the U-joint how do you know when enough is enough?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Thread Tools
Display Modes
