Old 09-09-2015, 10:40 AM   #1
Bruce VA
Default Water temp?
Car is a 1929 Tudor w/ a 1931 engine; 160* thermostat (w/ 3 weep holes), 4-blade fan, fan shroud, side pans, clean radiator, 50/50 anti-freeze & a new water pump.
With a probe in the radiator water, I consistently get 192* at 80-90* ambient temperature with the engine running for 10-15 minutes. That coincides with the line on my radiator cap gauge that reads "average summer temperature". And that is where it stays w/ little variation while driving.
So.......my assumption is that every thing is working as Henry designed it. Agree?
Bruce VA is offline   Reply With Quote
Old 09-09-2015, 11:19 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Water temp?
You're doing fine, though the temp may indicate the radiator isn't cooling like a new one would. Just keep the coolant clean and enjoy until it boils over, if that ever happens.
Old 09-09-2015, 01:25 PM   #3
H. L. Chauvin
Hi Bruce,
Thanks for sharing good news in what appears to be that you have a proper functioning 1929 cooling system.
Not seeing what other's may have ..... not knowing if one ever "over-greases" one's water pump ..... it is never a bad idea to remind others that "over time", Model A coolant temperatures usually "increase" in lieu of coolant temperatures "decreasing".
Just in general, for anyone who might read this post at a later date, it is never a bad idea to continue to monitor coolant temperature occasionally ...... and if coolant temperatures increase, radiator cleaning with about a half cup of dish detergent followed by flushing with clear water will never hurt to help maintain one's Model A cooling system.
Over heated engines wear out quicker.
Also, for final radiator filling, distilled water provided in one's radiator has no mineral impurities which can cause harmful mineral deposits known to clog small radiator tubes.
Simple and proper "MONITORING" and maintenance of Model A's is never nearly as expensive as poor maintenance followed by rebuilding often.
H. L. Chauvin is offline   Reply With Quote
Old 09-09-2015, 02:28 PM   #4
modelAtony
modelAtony's Avatar
Seems kinda warm for outside temp being 80-90. Doesn't give you much room for getting engine hot. Have fun modelAtony tony white Lafayette, LA unless this engine temp is from a parked running car for all this time. That can make a big difference.
modelAtony is offline   Reply With Quote
Old 09-09-2015, 09:31 PM   #5
RonC
RonC's Avatar
The ideal operating temperature is approximately 160 to 195 degrees. Cylinder wear is reduced when an engine operates between those temperatures.
RonC is offline   Reply With Quote
Thread Tools
Display Modes
