Old 09-09-2015, 10:31 AM   #1
DennisR
DennisR's Avatar
Default Horn amps
What amps does the Sparton pull?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe
DennisR is offline   Reply With Quote
Old 09-09-2015, 11:15 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn amps
Mine takes 4 to 5 amps. If you are using a battery charger only rated 4 or 5 amps it might take more to get the motor spinning, but while spinning it draws 4 to 5 amps when it's adjusted correctly.
Old 09-09-2015, 11:20 AM   #3
DennisR
DennisR's Avatar
Thanks Tom, thought it was about that, just needed confirmation, Dennis.
Old 09-09-2015, 01:10 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
Mine shows about 10 amps and mine is a Stewart Warner.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-09-2015, 02:11 PM   #5
Tom Wesenberg
Make sure neither field is grounded. I worked on a horn once where the motor spun OK, but one field was shorted. Just touch the ohm meter leads to one horn terminal and one to the horn mount or horn motor frame. You should get no meter movement.
I'll retest a horn later today to see what it draws.
Old 09-09-2015, 03:43 PM   #6
Fullraceflathead
I'll try that. I just cleaned the Commutator yesterday. It seems OK, but no change in the Amp draw.
-Henry Ford
1941 Willy's Pickup
Old 09-09-2015, 11:26 PM   #7
Tom Wesenberg
I just measured my Stewart Warner and got 6 amps. I'll try to remember to measure my Sparton tomorrow.
Thread Tools
Display Modes
