Old 05-09-2013, 12:31 PM   #1
Larry Dowell
Angry stalling
today I went for a drive and I could not keep my spt cp. running at a stop...yesterday when I drove it it ran fine but today it just wants to stall...I did'nt do anything to it ..if I push vac.to retard it stall and barly run at full advance....tried to adjust carb but still stalls any suggestions?
Larry Dowell is offline   Reply With Quote
Old 05-09-2013, 12:36 PM   #2
P.S.
Default Re: stalling
Vacuum leak? Leak around manifold?
P.S. is offline   Reply With Quote
Old 05-09-2013, 12:38 PM   #3
Franchise_24
Franchise_24's Avatar
Adjustment screw could have vibrated on the carb, I've had that happen to me before...
1928 Model A Ford Fordor Sedan Leatherback
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 05-09-2013, 12:39 PM   #4
P.S.
Re-read the post:
Old 05-09-2013, 12:43 PM   #5
Hicktick
Hicktick's Avatar
Sounds like your timing slipped .
Hicktick is offline   Reply With Quote
Old 05-09-2013, 12:44 PM   #6
1931 flamingo
1931 flamingo's Avatar
Fuel flow??
Paul in CT
Old 05-09-2013, 12:57 PM   #7
steve s
steve s's Avatar
Does it idle ok when the engine is cold? If the problem is only after warmup, this thread will soon be taking an ugly turn.
Steve
steve s is offline   Reply With Quote
Old 05-09-2013, 06:11 PM   #8
1931 flamingo
Dum-de-dum-dum, dum...................................NO Not v/lock ! ! ! Steve...
Paul in CT
Old 05-09-2013, 06:23 PM   #9
spdway1
spdway1's Avatar
I had a similar problem last spring, It ended being the Idle jet, the long one that hangs down from the top part of the carb, I took it out and cleaned it. Perfect.
http://modelabasics.com/carb%20basics%202.htm
spdway1 is offline   Reply With Quote
Old 05-09-2013, 08:06 PM   #10
Phil
Phil's Avatar
Just for grins and giggles, take a quick look at the points-- some times the A will do this if they close up.
Phil is offline   Reply With Quote
Old 05-09-2013, 08:32 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
The stalling is caused by the float being set too high. If the float is set too high it will cause too much gas to enter the bowl of the carb. Too much gas in the bowl will slosh foward and then back, causing the engine to stall apon brakeing.The other problems are not related. I don't understand what you mean by when you push the vac to retard. It sounds like the timing isn't set properly. The points gap is probably also off.
Old 05-09-2013, 08:59 PM   #12
Larry Dowell
thanks for the info ...only thing I can think of is I took a wolf whisle off the manifold and plugged it...maybe a leake there...
Old 05-10-2013, 07:27 AM   #13
Smurkey
Smurkey's Avatar
Get it running and squirt some carb cleaner on suspect areas of a vac leak. RPMs will go up if there's a leak when the cleaner gets sucked in. Found a gremlin in a two-piece Nash intake this way.
Smurkey is offline   Reply With Quote
Old 05-10-2013, 08:14 AM   #14
sphanna
sphanna's Avatar
spdway 1, Purdy Swoft,and Smurkey have nailed it. Those three posts contain your problem someplace.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 05-10-2013, 03:36 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
TIMING NEVER "SLIPS" OR "JUMPS" UNLESS THE CAM LOBE SCREW IS LOOSE OR THE LOCKWASHER UNDER THE SCREW IS MISSING!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Thread Tools
Display Modes
