Old 01-11-2019, 11:45 AM   #21
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Default Re: After Sandblastig...What have you found...
What have I found after sand blasting? I found out that I need a Beer.
dansluck is offline   Reply With Quote
Old 01-11-2019, 08:58 PM   #22
markwilltoo
The only way to prevent rust from eventually bubbling through the paint some years later is to use quality automotive grade epoxy primer under your paint. It's expensive, but will not allow any moisture pass through the finish. Lacquer primer begins absorbing moisture from the air as soon as it dries and will eventually rust through the primer, depending on ambient humidity if not top coated
Phosphoric acid goes inert once dry and will not provide long term protection if exposed to high humidity.
markwilltoo is offline   Reply With Quote
Old 01-18-2019, 06:42 PM   #23
Osage Orange
Sunlight
Osage Orange is offline   Reply With Quote
