Old 04-15-2018, 09:51 PM   #1
mgtf1500
Default Oil mist on left side of engine
I have a car that mists oil form somewhere -- Breather Cap? Dip Stick hole - some other unknown place. Where does this mess come from and how do I fix it?
!931 Deluxe Delivery
Thanks again.
mgtf1500 is offline   Reply With Quote
Old 04-15-2018, 10:03 PM   #2
Bulligen
Bulligen's Avatar
Default Re: Oil mist on left side of engine
Its your breather. Without taking you engine apart, sometimes a road draft tube gets the fumes to down under the car where they are carried away. Or you can put a white cotton sock over it to catch the oil. You can then actually see how much oil vapor you are catching? You probably have some weak rings.
Bulligen is offline   Reply With Quote
Old 04-15-2018, 10:51 PM   #3
Charlie Stephens
Be sure the dip stick is all the way into the block.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 04-16-2018, 05:55 AM   #4
HDowse
HDowse's Avatar
The vendors carry the accessory unit that fits into the breather tube and carries the mist to under the car. Here's the one from Snyder's: https://www.snydersantiqueauto.com/oil-breather
HDowse is offline   Reply With Quote
Old 04-16-2018, 07:26 AM   #5
WHN
I would add the breather tube from Snyder’s, we have used on all the Model A’s we have owned.
If you have a high mileage engine, you might want to also try a heavier weight engine oil. 20w-50 is used by a lot of guys in the Model A.
Add the breather, you will be happy with the result. Enjoy.
Old 04-16-2018, 08:54 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Where do you have the oil level, if it is at the "F"or above I have seen oil spray out the breather till it gets below the "F", try lowering the oil level some
Kurt in NJ is online now   Reply With Quote
Old 04-16-2018, 12:41 PM   #7
Ron in Quincy
Ron in Quincy's Avatar
You can use a plain copper scrub pad, cut a large piece and place it in the tube under the oil cap, push it down to the louvers. As the oil collects on the pad it will run back into the oil pan and not end up on the left side of the engine.
Works well for me for a lot of years.
Ron
Ron in Quincy is offline   Reply With Quote
Old 04-17-2018, 10:07 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ron
BUT, adding ANYTHING, in the tube or cap raises crankcase pressure & causes more leakage, especially at the REAR MAIN.
Mist is mainly a problem at higher speeds & longer runs, THEN, just use a sock & don't WURRY about it. It's just one of Model As IDIOSYNCHROCIES!
IDIOSYNCHRIC, was Greggs, (RIP!) one word definition of me! I considered it as a COMPLIMENT.
Bill Practical
"THE ASSISTANT GURU OF STUFF"
Old 04-17-2018, 03:34 PM   #9
GMCPASO
GMCPASO's Avatar
SST scowling pads work well, that is what I use. No rust that way.
GMCPASO is offline   Reply With Quote
Old 04-21-2018, 03:36 AM   #10
woofa.express
woofa.express's Avatar
Ron
good one Ron.
woofa.express is offline   Reply With Quote
Old 04-16-2018, 02:08 PM   #11
GMCPASO
GMCPASO's Avatar
# 7 works very well with weak rings and blow-by.
Old 04-17-2018, 10:13 AM   #12
BillEbob
BillEbob's Avatar
You made me go back and count each response to see which one was #7! lol
BillEbob is offline   Reply With Quote
Old 04-17-2018, 11:24 AM   #13
Y-Blockhead
Y-Blockhead's Avatar
With the added benefit of it acting as a Road Draft tube.
Y-Blockhead
'30 Briggs Town Sedan
_________________________________
And once again that is just my 1 worth.
Old 04-16-2018, 04:49 PM   #14
jg61hawk
I have a 1929 Roadster and it has the larger Model B filler. I never had a problem, but two of my friends got cars after me with the stock more narrow original tube. We have switched both cars now to the wider, longer Model B tube...fixed that problem of blow by. Not original but FORD and better than new!
jg61hawk is offline   Reply With Quote
Old 04-16-2018, 05:32 PM   #15
Synchro909
Those oil breather tubes are another example of the LHD focus of parts houses. There is nothing provided to secure the lower end of the tube. I wire it to the engine mount but it is and looks rather crude.
I belong to a procrastinator's club but we haven't met yet.
Old 04-16-2018, 06:58 PM   #16
johnneilson
There is also the PCV option.
See Brierleys book, mine works very well.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 04-16-2018, 08:08 PM   #17
Railcarmover
Railcarmover's Avatar
stock breather and a right side breather off the valve cover,upper rear..
Railcarmover is offline   Reply With Quote
Old 04-16-2018, 11:13 PM   #18
PC/SR
Look at the center main bolt. Seepage there sometimes.
PC/SR is offline   Reply With Quote
Old 04-17-2018, 09:27 AM   #19
Benson
Benson's Avatar
A caution:
I have seen "steel wool" used in place of copper pot scrubbers in breather tube.
Water vapor collects on steel wool which causes rust then as steel wool falls apart the small pieces of steel wool drop into the oil pan and get in bearings etc.
Old 04-17-2018, 10:09 AM   #20
Joop
Joop's Avatar
Maybe check first if your oil breather/filler pipe is oriented the right way as in the picture. JP
Joop is offline   Reply With Quote
