Old 01-11-2012, 12:11 PM   #1
David Lien
Default Crab Dist Adapter
I have a 59 AB engine with a Helmet Dist. Can someone tell me where to purchase an adapter to run a 42 Crab dist???. I have two good crab Dists. and would like to run on of them.Thanks
David Lien is offline   Reply With Quote
Old 01-11-2012, 12:43 PM   #2
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: Crab Dist Adapter
I think this is what you need:
http://www.speedwaymotors.com/Flathe...pter,6003.html
Plus, 2-3 bolt plate that you can probably get from Bubbas, or ThePitstopGary has one as well - about $55.
TomT/Williamsburg is offline   Reply With Quote
Old 01-11-2012, 12:44 PM   #3
oldford2
oldford2's Avatar
Dick Spadaro.com
800-222-3248
oldford2 is offline   Reply With Quote
Old 01-11-2012, 12:48 PM   #4
ken ct
Oh,John i didn't know Dick carried them,thanks. ken ct.
ken ct is offline   Reply With Quote
Old 01-11-2012, 02:41 PM   #5
David Lien
Thank you very much for the help. You guys are the best;
David
Old 01-11-2012, 03:35 PM   #6
OLD...BILL
OLD...BILL's Avatar
Dave: NO ..adaptor plate. get the original front cover plate two bolts. stock engine timing cover plate.. keep it all stock and all Ford, the adaptor plate adds about 1/2 inch. moves the dist. out and you haft to run the cam extender, may come with the adaptor plate ?? and the vacuum conector is or maybe with the adaptor plate too ?? more junk... with the stock timing cover its. all there, no extra stuff. less change for oil leaks too... Mac's and others supplers have the stock plate page 46,in there cataloge and for $24.75 plus ship...... OLD....BILL
OLD...BILL is offline   Reply With Quote
Old 01-11-2012, 08:05 PM   #7
Randy
Randy's Avatar
In my experience, helmet distributors are not usually on 59AB engines, they have the crab distributor housing with either the flat, Mallory style, cap or they have the large plastic cap with the rubber boot on each side. If you have that, then you can just add the '42 clips and a '42 cap. If a helmet distributor is on a 59AB then it may already have an adaptor or it may have the wrong cover on it. I guess that's the thing to check is whether your timing cover is a 2 bolt or 3 bolt?
Randy is offline   Reply With Quote
Old 01-11-2012, 09:27 PM   #8
ken ct
You would also need the 42 rotor not the same one as 46-48. ken ct. Also use the small rubber nipples on the wire to cap 9 of them.
Old 01-11-2012, 10:29 PM   #9
David Lien
Thanks all::
This engine has a three bolt timing cover and a helmet Dist. I think with the help here I now have this figured out. Thanks again
David
Old 01-12-2012, 01:49 AM   #10
ken ct
Personaly i think your going through a lot of trouble and work to gain almost nothing. Helmets run just as well as the crab when done up right. OMO ken ct.
Old 01-12-2012, 10:01 AM   #11
Ralph Moore
Ralph Moore's Avatar
Doesn't the helmet dist have to have the longer cam snout with the original three bolt cover?
Ralph Moore is offline   Reply With Quote
Old 01-12-2012, 02:38 PM   #12
Mart
Mart's Avatar
If you have a helmet dizzy currently running and you take it off, a crab style dizzy will bolt up with just the adaptor, no spacer required.
I have this setup on two of my engines.
Mart.
Old 01-12-2012, 02:45 PM   #13
Mark Slight
Mark Slight's Avatar
It's a distributor!
Mark Slight is offline   Reply With Quote
Old 01-12-2012, 02:48 PM   #14
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I would have to agree with some of the others. although we do tons of the crabs the helmet is just as good in all respects...
Both are very good examples of early Frod ignition and are just about perfect when matched up with good parts, coil and a proper set up...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-13-2012, 09:21 AM   #15
Ralph Moore
I'm still a bit confused The adapter you speak of is the three bolt to two bolt, like speedway sells? Then no "button" is required when combining the crab with the longer cam?
Old 01-13-2012, 10:14 AM   #16
ken ct
Both styles of the pancake dist have long snouts on them obviously to reach in further to reach the shorter cam in the 42 and up engines.Unless the mount surface of the 2 bolt cover is further out more than the helmet covers. Then why is 1/2" spacer made in the first place. ??? ken ct. I am NOT talking about the button which is a diff situation again.
