Old 06-03-2013, 02:35 PM   #1
BadgerA
BadgerA's Avatar
Default License Plate Clip Finish Question
What is the correct finish for the bolt, lock washer, and nut on the 28 license plate clips? According to Isbell's book,,, it states the bolt was plain, the washer and nut were raven. Seems strange, but I am soliciting input.
BadgerA is offline   Reply With Quote
Old 06-03-2013, 03:30 PM   #2
160B
160B's Avatar
Default Re: License Plate Clip Finish Question
According to The Restoration Guidelines and Judging Standards page 18-3 revised 2011
"The clips were attached to the head lamp bar with unfinished 1/4"-20 X 1" hex head (3/8" X 1/4") bolts, unfinished lock washers and cadmium plated 1/4"-20 (3/16" X 1/2") hex nuts. Very early vehicles may have been assembled with raven finished hex nuts."
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-03-2013, 08:03 PM   #3
glenn in camino
glenn in camino's Avatar
On some 28, show cars I've seen the bolts are installed from the back with the nuts on the front. Which way is correct?
glenn in camino is offline   Reply With Quote
Old 06-03-2013, 08:34 PM   #4
160B
160B's Avatar
Continuing on from the above paragraph
"The bolts were installed from the radiator side of the head lamp bar. The assembly sequence was bolt, clip, headlamp bar, clip, lock washer, and nut."
From page 18-2 revised 2011
"Ribbed clips that hung the license plate below the bar and were used from the beginning of production until May 1929'
Old 06-04-2013, 12:04 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The license plate isn't listed in the sequence.
I'd guess it only makes sense that it fits on the front side of the clips.
Old 06-04-2013, 02:19 AM   #6
Gary Karr
Gary Karr's Avatar
BadgerA,
The bolt, nut, and lock washer are all cad. The clips are black enamel. On '28's the nuts face forward and the clamps hang down below the bar.
Gary Karr is offline   Reply With Quote
