06-23-2018, 12:47 AM | #21 |
Re: 8BA Flywheel/Clutch....I've Read TOO Much
okay i'm thick... from the the original postman. The splines on the disc should be the same, if not you have the wrong clutch disc, you can put a 9" or 9.5? disc on a 10" or 11" clutch plate it"ll work. but it'd be better to match. Did i miss something? Seems like you have a miss match or some issue with your clutch plate....
