12-17-2017, 10:36 AM | #1 |
Wire disc on 55
Can someone tell me what problems I will have installing a set of wire wheel discs on my 55..I have a bit of an idea as to how the clips work but wonder about the faceplate on the continental? Do I need to take the cover ring off plus the facelate and do I need to do any mods to the partial faceplate itself as it now covers the wheel completely to the original wheel cover..So I really don't want to spend a pile to get into a pile of trouble that is..PS This is the original style cont kit..Thanks Barners
12-17-2017, 12:31 PM | #2 |
Re: Wire disc on 55
Are you asking about on a '55 Thunderbird, or something else?
The original wire basket style wheelcovers in '55/'56 were held on with spring clips. After-market versions are available that snap on like most all newer wheelcovers. There was no "factory" cont kit on '55 T-Birds but there were a few after-market and/or 'dealer installed' versions, as well as diy projects. >edit< Is this for the '55 Crown Vic you've mentioned in other posts? Close-up photos of the existing 'as installed' opening in your spare tire cover may help. The wire basket style wheelcover does cover the outer lip of the wheel, approx 12mm in depth and is also slightly larger in diameter than the wheel. . Last edited by dmsfrr; 12-17-2017 at 09:38 PM. |
12-17-2017, 02:42 PM | #3 |
Re: Wire disc on 55
OK i have been on here before and my car is a 55 crown vic..The faceplate on my continental kit looks much like the one on the green bird but the original wheel cover does not sit down inside the faceplate but rather rests on top edge and actually covers a bit of the faceplate So is it possible that the new wire covers just cover a bit more of the faceplate??? Thanks
12-17-2017, 02:46 PM | #4 |
Re: Wire disc on 55
PS could not bring the black or blue in for a better piture..Enlarge that is..
12-17-2017, 07:30 PM | #5 | |
Re: Wire disc on 55
They're photos I copied from somewhere so there wasn't too much I could do with them. There is no cover panel over the tire on the black car. What almost looks like a white tire cover is actually the wide whitewall. 55 with kit 2c.jpg 55 with kit c.jpg Last edited by dmsfrr; 02-03-2018 at 01:34 PM. |
12-17-2017, 07:59 PM | #6 |
Re: Wire disc on 55
12-17-2017, 08:10 PM | #7 | ||
Re: Wire disc on 55
If you've never had the pleasure of having these on a set of wheels.... Photo 1. The spring clips hook onto the outer lip of the wheel and have another hook at the inner end to fasten into a lip on the back of the wheel cover ring. (photo 2) The square-ish rubber piece on the spring clip is to keep the wheel cover from rattling against the wheel or rubbing on the tire. Photo 3. Side view of back side Photo 4. Overall outside diameter of the wire wheel cover ring. Approx 16 & 5/8 inches. (422mm) Photo 5. Outside diameter of the center tapered portion. Approx 13 & 3/8 inches. (340mm) I would imagine something could be used to prevent the outer back edge of the wheel cover ring from scuffing the paint around the opening in the spare tire cover. . Last edited by dmsfrr; 12-18-2017 at 07:14 PM. |
02-03-2018, 09:43 AM | #8 | |
Re: Wire disc on 55
The wire wheel cover itself, did it "push-in - swivel" with those retaining clips to go against the wheel/tire assy? (Let's see how long this photo will stay up... )
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-03-2018, 01:55 PM | #9 |
Re: Wire disc on 55
KULTULZ, The wire basket portion pushes/pulls straight in and out on the flat springs.
The springs flex enough to create an over-center effect that can hold it out, or firmly in against the rubber bumpers. For Ford coupe, I found another photo of the wheel opening in a tire cover, although with wire wheels on a '56 Bird. Last edited by dmsfrr; 02-03-2018 at 02:19 PM. |
02-03-2018, 02:21 PM | #10 |
Re: Wire disc on 55
APPRECIATE THAT!
I learned something today...
