Old 10-04-2019, 08:30 AM   #1
adileo
adileo's Avatar
Default 52 f1
Truck starts and runs very well. However, I noticed the other day that in either 2nd or third gear if I need to get on it, instead of winding out. It bogs down. I thinking starving for fuel. My fuel pump was built by Charlie NY, so doubt it’s that. Carb is maybe a year old from Carpenter. I purchased an nos old style (brass) fuel filter, which you can clean and reuse about a year ago. I’m thinking that is 1st and easiest to fix or replace.
Curious if you folks have other ideas.
Truck was also recently tuned up. Plugs, wires, rotor, points and condense. I did not adjust timing.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-04-2019, 08:52 AM   #2
tubman
tubman's Avatar
Default Re: 52 f1
You should probably check the timing. Replacing the points can cause the gap to change, therefore the dwell, and consequently the timing. Probably not it, but you should recheck the timing every time you change the points.
Old 10-04-2019, 10:11 AM   #3
adileo
adileo's Avatar
Default Re: 52 f1
Thanks, since I very recently replaced the points. I will do as you suggested.
Reading the shop manual it’s not clear. After I disconnect vacuum do I plug it to set w timing light?
Thanks
Andy
1952 F1
Old 10-04-2019, 10:43 AM   #4
40cpe
40cpe's Avatar
Default Re: 52 f1
Instruction say to plug the line from the carburetor. There shouldn't be any vacuum on the line at idle, but it only takes a second to block it. The vacuum source is removed from the advance canister, which is the objective.
I agree that the filter (or other flow restriction) would be the first suspect.
Old 10-04-2019, 10:44 AM   #5
40cpe
40cpe's Avatar
Default Re: 52 f1
Delete duplicate
Old 10-04-2019, 07:00 PM   #6
Ross F-1
Ross F-1's Avatar
Default Re: 52 f1
I'd be surprised if it's the filter. I would think that even with a relatively clogged filter the carb bowl would be full at the point you stomp on the pedal. If it gradually lost steam, then I'd believe it.
I'd bet on the timing. Be sure to check the vacuum advance too.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
