Old 11-26-2017, 09:09 PM   #1
Bursonaw
Bursonaw's Avatar
Default Oil filler tube
Looking at my oil filler tube, it has the center tube installed but not the outer tube.
Can anyone tell me if you need the outer tube for the vent to work properly?
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 11-27-2017, 10:05 AM   #2
cas3
Default Re: Oil filler tube
if you run without it you will most likely have an oily mess around the breather cap
Old 11-27-2017, 10:20 AM   #3
Bursonaw
Bursonaw's Avatar
Thanks, when I pulled mine out to change the manifold it did not have the outer tube. I had been running the car for a few years that way but it seeped oil around the base.
Old 11-27-2017, 10:48 AM   #4
FrankWest
FrankWest's Avatar
Isn't that tube too short? I think it should be approx 6 inches high
FrankWest is offline   Reply With Quote
Old 11-27-2017, 07:03 PM   #5
cas3
frank, the short tube shown is the common later length. the tall one you are thinking of is 33-34 for sure, and then sorry i do not know when the short ones came in. 35 or 36 i'm guessing
Old 11-27-2017, 08:02 PM   #6
bbrocksr
Yes ,you need the tube for the ventilation system to work properly.
Bill
bbrocksr is offline   Reply With Quote
Thread Tools
Display Modes
