06-27-2019, 06:06 PM | #1 |
Carburetor rebuild
Who is the best person to rebuild my grubby carburetor?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-27-2019, 06:20 PM | #2 |
Re: Carburetor rebuild
Try contacting this guy;
https://www.modeltfordclubofamerica....php?f=5&t=4552
I know the voices aren't real but damn they have some good ideas! |
06-27-2019, 07:06 PM | #3 |
Does it need a rebuild? Or just a good cleaning?
06-27-2019, 08:51 PM | #4 |
By this time, probably needs rebuilt. Chances are the throttle shaft/hole is worn and cork float past usage and other then that maybe a gasket set. Depending on what you see inside if you pull the cover off; They used a pot metal ventura that is almost impossible to get out due to swelling and cracking. You then need at least one special tool or have to make one, to get the spray needle seat out if it needs to removed. There is a little more work to set the G up then getting the fuel level puddle correct like on an NH, the idle pickup tube needs to be set too. If you have the Model T Service Bulletins it tells how. I am slowly working on one now. By the way just to let you know, it is a Holley G. You can get some but not all parts new.
06-29-2019, 09:51 AM | #5 |
The Holley G is one of the simplest carburetors to rebuild. I bet you could do it yourself. Here's how:
https://modeltfordfix.com/rebuilding...-g-carburetor/
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
07-13-2019, 11:28 AM | #6 |
07-13-2019, 06:32 PM | #7 |
Hey Chris judging by the condition of that carb, you probably have a lot of other things that "need re-building"
Let us know how you make out. |
07-14-2019, 12:35 AM | #8 |
Not too much. Mostly just the engine, transmission, front axle, rear axle, suspension, radiator, steering box, Brakes, and a few other things.
07-14-2019, 05:34 AM | #9 | |
You got a wealth of T info and parts with Glen Chaffin and Milt Webb on the left coast |
07-14-2019, 04:13 PM | #10 | |
He has an interesting setup. He lives in a beautiful Victorian home with his two story garage behind it. He also owns the house next door which houses his parts business. Every inch of that home is racks full of new parts.
07-19-2019, 06:19 PM | #11 |
My engine looked like that and later I found out during the rebuild that the oil line inside was plugged so no oil was getting to the front of the old engine aside from whatever was coming from further back inside, boy things were well worn for sure.
