06-16-2019, 08:15 PM | #1 |
36 Car Headlight buckets
My clips at the bottom have broken off on both buckets. Just wondering if anyone has a good repair for this. I’ve searched the board and can’t seem to find this question before. I doubt I’m the first one this has happened to. I was thinking of using small diameter short screws and a nut run up tightly to the bottom of the bucket. I’d hate to do that if someone has a better suggestion. Thanks!
06-16-2019, 09:41 PM | #2 |
Re: 36 Car Headlight buckets
Try looking in the model A parts places like Brattons,Snyders
06-16-2019, 09:56 PM | #3 |
Thanks!
06-17-2019, 03:12 AM | #4 |
You might have to make them.Here is a pic of a '35 head light bucket.You can see that they are riveted.
06-17-2019, 03:27 PM | #5 |
Does this help?
This is Bob Drake, but others carry them. |
06-17-2019, 04:02 PM | #6 |
06-18-2019, 05:08 PM | #7 |
Just to clarify the Drake kit shown is for the latch on the headlight trim ring and not the head light bucket itself.
06-18-2019, 08:12 PM | #8 |
The Bratton clip should do the trick with a few holes drilled for rivets
06-20-2019, 05:24 AM | #9 |
Crabby...If fixing yours doesn't work out for some reason, Dennis Carpenter has quite a few 36 passenger buckets in their NOS department. There are a few 40/41 seal beam buckets mixed in with the bunch, on the shelf. I do not believe that they are NOS, but they all appeared to be good buckets when I looked through them in April.
