12-07-2017, 09:04 PM | #1 |
no start 26 T
Friends T 26, Spray carb, battery good, cranks over, fuel to carb,spark all good,but no fuel getting to motor, starter fluid will keep it running?
www.whidbeymodelaclub.com |
12-07-2017, 09:14 PM | #2 |
Re: no start 26 T
Gas turned on? needle valve opening? Maybe blow out the gas line or clean the tank.
12-07-2017, 09:18 PM | #3 |
Re: no start 26 T
Carb is filling with gas,tank, lines cleaned.spray with starter fluid-it runs.
12-07-2017, 11:46 PM | #4 |
Re: no start 26 T
You say carb is filling with gas but gas not getting to engine. I kind of went through the same thing on my 26 coupe and finally pulled the carb, took it apart (removed bowl, float pin, float) and thoroughly cleaned it. Reassembled it and bolted it back in place. Fired right up. Gas was getting into the carb bowl, but not refilling the bowl at a sufficient pace. I figure I had crud in the needle seat or some such thing. It's not a hard job to unbolt the carb and clean it with carb cleaner. Spray every crevice good and reassemble.
12-08-2017, 02:10 AM | #5 |
Re: no start 26 T
Could also be a vacuum leak.
I know the voices aren't real but damn they have some good ideas! |
12-08-2017, 02:12 AM | #6 |
Re: no start 26 T
