Old 10-19-2019, 10:13 AM   #1
Leatherback 57
Leatherback 57's Avatar
Default Fuel shut off
My fuel tank has no rust shiny clean and has screen on shutoff but after several month it starts to leak past . I've replaced at least 3. Buy from Snyder's and other vendors as well. Same valve. Is it the Ethenol in fuel?? Anyone else have this problem?
Leatherback 57 is offline   Reply With Quote
Old 10-19-2019, 10:51 AM   #2
Badpuppy
Default Re: Fuel shut off
If it leaks at the shaft, you should be able to remove the handle and tighten the packing nut to seal it back up. Works for most all valves. New valves often need this done after wear-in.
Old 10-19-2019, 11:18 AM   #3
Leatherback 57
Leaky fuel to carb. Tried to take apart one of the valves and are not repairable like the old ones???
Old 10-19-2019, 11:49 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Packing is also available for the original cut off valves . I overhauled the original cut off valve with new packing and it doesn't leak a drop .
Purdy Swoft is online now   Reply With Quote
Old 10-19-2019, 04:02 PM   #5
duke36
Yup; not for show, but get rid of the orig. style and use a new modern lever ball valve cut into the gas line with compression fittings. If inside valve, don't want fuel inside the car. Suggest also to replace the valve also with a direct 90 deg fitting at the tank.
Old 10-19-2019, 04:13 PM   #6
Tom Endy
Tom Endy's Avatar
I believe that they all leak through after any amount of use. I have replaced the indented firewall fuel valve three times and it still leaks through.
Where do I find the modern ball valve that fits the firewall?
Tom Endy
Old 10-19-2019, 04:17 PM   #7
wmws
wmws's Avatar
I have had the same trouble. The last three I got from the vendor leaked right out of the box. I sent them back for free replacement and finally got one that doesn't leak at least for now about 6 months.
wmws is offline   Reply With Quote
Old 10-19-2019, 05:39 PM   #8
Fhane
Try Amazon. 3/8 mini ball valve.
Fhane is offline   Reply With Quote
Old 10-19-2019, 09:29 PM   #9
CarlG
CarlG's Avatar
Tom Endy
Not your "original" set-up, but I bought the ball valve from Amazon. (It also has an electric shut-off just downhill from the filter.)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-19-2019, 10:09 PM   #10
duke36
Tom Endy
I get my 90 deg from Ace Hardware, Amazon, MSC DIRECT, or similar with viton seal. Recollection it's 1/8" MINI with compression and assorted brass fittings to connect after the filter. Check on line.
Old 10-20-2019, 12:07 PM   #11
Ernie Vitucci
Good Morning...You can also find the 1/4 turn ball valve shut off in the Bratton's 2019 catalogue on page 61. $61.05. It connects to a standard shut off which you install and never touch again...Ernie in Arizona
