Old 01-19-2014, 06:21 PM   #1
Brooks
Brooks's Avatar
Default 40 door hinges replacement
Has anyone replaced 1940 coupe door hinges with Bob Drake hinges? Bottom body hinge holes are drill wrong on my.
Brooks is offline   Reply With Quote
Old 10-15-2019, 09:31 PM   #2
Stillrunners
Stillrunners's Avatar
Default Re: 40 door hinges replacement
anybody ?
Stillrunners is offline   Reply With Quote
Old 10-15-2019, 11:34 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Give Bob an his boys a call. Dollar to a donut...."We've NEVER heard that problem before! DD
T5 W/TORQUE TUBE
I may not be the BEST, but I'll do 'til he gets here!
Old 10-16-2019, 07:59 AM   #4
TJ
TJ's Avatar
Need some clarification here. Are you wanting to use Drake hinges because the holes are wrong on yours or the body? Or do you already have Drake hinges and the holes are wrong in the Drake hinges?
Old 10-16-2019, 08:16 AM   #5
Stillrunners
Did a search as I'm at the point of no return on my driver's side bottom hinge. Was hoping it was the hinge that is sprung and not the door needed work. Right side is a nice closing door but the left binds about a foot before closing. You can see the bottom hinge area of the door has been tweaked a little. With the safety latch on it will open further than the right side - which is going past the cowl.
Also was needing opinion of who makes the best replacement hinges ?
Old 10-16-2019, 08:48 AM   #6
Karl Wescott
Karl Wescott's Avatar
If your hinge is in overall good condition, do not replace it.
Acquire a 3 ft length of 9/32 drill rod (O-1 tool steel at McMaster-Carr). Use this to determine that the upper and lower hinges are on the same axle. The binding you describe sounds like they are not.
Karl Wescott is offline   Reply With Quote
Old 10-16-2019, 10:23 AM   #7
19Fordy
19Fordy's Avatar
Karl makes a good point.
